Sloppy 4-speed shifter
Old May 5, 2022 | 06:15 PM
Jhall1021's Avatar
Jhall1021
Working my way through some issues on my newly acquired ‘78 f150 6 cyl 2wd. Truck is in great shape but there’s about 5” of left to right play in the shifter. It makes driving pretty tough. Finding gear is just tough with so much play. I pulled the boot off to see if there were any bushings or something along those lines but the shifter shaft seems to go directly into the transmission. If anyone has any ideas or suggestions thank you in advance!
Old May 5, 2022 | 06:27 PM
85e150's Avatar
85e150
Does this transmission have a granny low first gear? Or is 4th OD?
What is the transmission code on the warranty plate?
Old May 5, 2022 | 06:29 PM
Jhall1021's Avatar
Jhall1021
First gear is a granny gear no overdrive.
Old May 5, 2022 | 06:43 PM
85e150's Avatar
85e150
OK so you have a T18 (all iron) or an NP435 (aluminum top cover).
Transmission code "A" on your warranty plate is the NP435.
Transmission code "F" is the Warner T18.
You probably need one or more of the parts that keep the shifter cane in the right spot relative to the shift forks.
Removal of the shifter cane is different for these, so determine what you have before you put a pipe wrench with a cheater on that retainer....
https://www.novak-adapt.com/knowledg.../manual/np435/
https://www.novak-adapt.com/knowledg...anual/t18-t19/
Old May 5, 2022 | 07:26 PM
Jhall1021's Avatar
Jhall1021
Really appreciate all the help! It appears I have a t18. Is there a write up anywhere that you know if that walks you through rebuilding the shifter components? Do I have to drop the tranny to do so?
Old May 5, 2022 | 08:32 PM
85e150's Avatar
85e150
Some help:
https://www.ford-trucks.com/forums/1...nsmission.html
https://www.ford-trucks.com/forums/9...ift-lever.html
(the cover unscrews on your trans)
https://www.ford-trucks.com/forums/4...arner-t18.html
If you can't fix this by the above methods with the stick and it's pins, spring etc, then you can pull your carpet back and get to the access panel in the floor of the cab. You can pull that panel and remove the top of the transmission if need be.
There are posts and videos etc on that as well if you get to that point.
89frankenford
Dec 1, 2008 12:30 PM
nrw1717
Nov 28, 2007 07:17 PM
mdjohnson
Jan 15, 2006 12:22 PM
