Reversed Rods?
Old May 4, 2022 | 10:22 PM
pntrbl's Avatar
pntrbl
Reversed Rods?
I'm putting my 390 back together and my memory bank ain't workin' to good. All my rods are stamped in numbered pairs on the same side as the tangs, but I'm not remembering which side of the block they were facing when I took it apart. I "think" with the motor upside down and the flywheel side to my left, that they would be on driver's side when flipped right side up. Does it matter? Other than the tangs the rods appear to be symmetrical.
Old May 5, 2022 | 04:04 AM
Crop Duster's Avatar
Crop Duster
Rods
The numbers and the tangs on the bearings go toward the outside of the block. Be sure the chamfer on the rod is toward the fillet on the crank. This is a 429 rod but Fords are all the same.
Old May 5, 2022 | 06:20 AM
1966F100SC's Avatar
1966F100SC
Bigger fillet on rods goes towards the crank, smaller two will face each other on the journal
Old May 5, 2022 | 09:47 AM
pntrbl's Avatar
pntrbl
Thanx guys. Perfectly sensible answer that I didn't think of ....
pntrbl
May 5, 2022 09:51 AM
bigreed91
Oct 5, 2014 08:51 AM
1976fordguy
Feb 9, 2013 06:18 AM
EgoMan
Oct 6, 2004 02:50 PM
RapidRuss
Mar 19, 2004 06:40 PM
