EFI to Dual Weber Setup
1993 Ford F-150, 4.9L I-6, EFI with dual tanks.
I am converting to a dual Weber setup from Clifford Performance. We have managed to get the fuel pressure under control but are having trouble with the return circuit. Since I have dual tanks, the switch selects which pump and return the fuel goes to. With the carb conversion alot of wiring has been simplified including how the return knows which check valve to open to allow fuel to return. If I delete the check valves, there is a danger that a tank can be overfilled.
I am converting to dual Webers to eliminate the head cracking problem that occurs because of poor fuel/air distribution in the intake system of the 4.9L. A problem that apparently plagues all of these engines.
The engine runs like a top using Clifford Performance's recipe for a torque monster 6 cylinder! (Clifford Performance - 6=8 Clifford Performance Intakes & Headers) (Shout out to Larry and his team!)
We just need to figure out how to be able to use both tanks without getting too complicated. Eventually, if I have to change the entire fuel system (selection/pump/return and all), I'll do it. Right now, I'm trying to get my project driveable again, so I can do the suspension and steering upgrades.
Any help and/or direction is appreciated
The return is connected to one side of the regulator and the other end to the submerged pump. This circuit contains a check valve that prevents fuel from returning to the wrong tank and overfills.
Yes, there is a fuel return. Look at the fuel schematics for the EFI.
Clifford Performance says there is a return and if I want to use dual tanks, I need to figure something out or use a different tank/pump/selector setup from an older, non-EFI truck.
If you are still using the dash mounted switch to control the individual pumps, I am not following your thought process about the check valves in the fuel delivery module ( pump assembly). Yes. There are dozens of threads about the check valves going bad causing all kinds of cross-flow problems including a tanks to overflow.
I would direct you to put it back to the way it was and send the carburetor kit back to Clifford. The picture they use for the 300 ad is a carbureted truck from the factory.
Yes, there is a fuel return. Look at the fuel schematics for the EFI. .
Fuel Delivery Module (FDM)
If fuel is getting into the unselected tank then you have a bad check or shuttle valve in the that tank. This crossflow issue plagues this vintage trucks.
If your fuel pumps are working correctly in both tanks, and you haven't messed with the factory fuel lines, switch and return, just connect the return to your regulator. Same way you connected the fuel line from tanks, to regulator.
There is only one return line from the EFI manifold.
WIth the fuel plumbing, looks like there should not be any issues you describe:
My4Fordtrucks: I have no intention of putting it back the way it was.
When I get the truck back, I will follow all the steps prescribed by the knowledgeable folks of this thread. Thank you for the input. Please don't hesitate to respond if something comes to mind. After the fuel system is finished, I will let everyone know what solution we came up with.
This way, you can delete the return line from the engine, keep your factory wiring, and all's right with the world.
I need to study all the schematics and see what can be done. I'm sure I'm overthinking this.
If you want to continue using electric pumps, you're going to have to graft in a control system like the '87 351/460 trucks used that used the oil pressure sensor and a bunch of relays to control the electric fuel pumps.
Converting EFI to carb is a never ending series of headaches. Then once you get it running it's a never ending series of headaches chasing driveability/tuning issues with the carb. Some people just love to fiddle with carbs though, so more power to you if that's you!
The carbs I'm using are Webers. Now before anyone gets excited, I know a Weber can be frustrating for the uninitiated and uneducated to setup. Fortunately, the shop I'm working with set them up on a flow bench. They matched my engine parameters, intake, cam, and exhaust setup and they came ready to run with minor tweaking. Also, I have been doing some research on the Weber and they seem to be remarkably simple. Most setup problems appear to be owner induced (trying to make it work when it's outside the parameters for the jets installed).
All that being said, I am bound and determined to make The Turd (as my wife affectionately calls it) a living thing of beauty.
I will keep everyone posted.
