Turning off TPS?
Old May 3, 2022 | 07:33 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Turning off TPS?
Is it possible to get a tuner to shut off the TPS on a 2012 f150. I’m going to run load E tires At higher pressure
Old May 3, 2022 | 08:51 PM
RLXXI's Avatar
RLXXI
Tuner will do the trick, might as well get a custom tune while your at it to improve performance. I use SCTx4
Old May 4, 2022 | 05:04 PM
Lone Wolff's Avatar
Lone Wolff
Based on context, assuming you mean the TPMS and not TPS. TPS is the Throttle Position Sensor and you would not want to disable that.
Disabling the TPMS with a tuner? = go for it!
Old May 4, 2022 | 07:22 PM
Conanski's Avatar
Conanski
Get a copy of Forscan with the extended licence and a suitable interface and you can set the TMPS to any pressure you want, it can be disabled too but it doesn't have to be,
P.S. Running a higher pressure that factory is no problem at all, you don't have to do anything to the system to prevent a dash light unless the tire sensors are removed from the wheels.
Old May 4, 2022 | 07:49 PM
rbentnail's Avatar
rbentnail
This was my immediate thought as well- if you're going to run a higher pressure why disable the TPMS? Unless the sensors are removed, I'd leave it alone. It'll still tell if pressure gets down to 30-ish.
Old May 4, 2022 | 07:51 PM
RLXXI's Avatar
RLXXI
It's set to each vehicles door placard.
Old May 9, 2022 | 10:35 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Sorry, yes meant tire pressure sensor. So the sensor only go off if pressure goes below 30psi? So with the load E tires at 50psi it wouldn’t trip it? The TPMS is bad in each rim. I bought the rims used and they never worked.
Old May 9, 2022 | 10:37 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
by setting does that mean at the low pressure to trigger the warning?
guess I need to look into a forscan program
Old May 10, 2022 | 12:03 AM
rbentnail's Avatar
rbentnail
Oohhhh, you didn't say you were replacing rims, only that you were switching to heavier load rated tires. I assumed you were just placing different tires on the same rims hence my "no need to disable" comment. Nevermind.
Old May 10, 2022 | 05:16 PM
Conanski's Avatar
Conanski
Yes correct.
No it would not.
The sensor is not built into the rim it's either strapped to the inside circumferance or it is in the valve stem, in other words it's an add-on that has to be installed before tires are mounted. These sensors are also battery powered and are manufacturer specific, so with used rims it's a good idea to replace the batteries in the sensors or replace them with new.
Old May 12, 2022 | 09:27 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Yes correct.
No it would not.
Sorry if I made it sound like the sensor was part of the rim. I was going to buy replacement sensors because as far as I could find out the batteries can't be replaced. But not knowing the complete functioning of the sensors, I thought they were set for a high and low pressure value, but sounds like only low pressure value. So I may get new sensors, have the tires broke down and new sensors put in. Can I get the new sensors to register with the truck computer without going to a dealer? It sounds like I should be able to from what I found.
thank you
Old May 12, 2022 | 09:32 AM
RLXXI's Avatar
RLXXI
thank you
Yes, I got a set from tirerack.com for my truck when I changed wheels. Follow the instructions in the owners manual to re-learn them to your truck.
Old May 12, 2022 | 10:17 AM
gDMJoe's Avatar
gDMJoe
Arrow
wildstang ... I was going to buy replacement sensors because as far as I could find out the batteries can't be replaced.
(batteries) -TRUE- They're expoxied within the sensor - life expectancy is 5-8 years depending upon wheel rotations (i.e. go dormant/-off- when sitting).
For your listening pleasure and reading enjoyment...
Ford Motorcraft Tire Pressure Monitoring System ««« -click- ...* PDF document
Get *new* OEM, Motorcraft (TPMS-12). STRONGLY recommend buying from ebaY® seller(s) (less $$$) just pay attention to the seller's feedback.
The procedure (as well as other TPMS information) is in the owner's manual.
(owner's manual) Don't have one -OR- would like a digital, searchable desktop document?
Owner's Manuals ««« -click-
( SEARCH BY VEHICLE - Year & Model )
» [ Choose Year ] » [ Choose Model ] » [ Search ]
Old May 13, 2022 | 08:48 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
thank you for the info. I'll look into this stuff
maxtor
6.7L Power Stroke Diesel
Jul 2, 2020 12:28 AM
kurboman
Sep 18, 2014 11:55 AM
Kevinpmac
64
Apr 20, 2008 12:27 PM
hansshanks
Nov 10, 2006 09:57 PM
AWM
Computer Chips & Tuners
Apr 9, 2003 10:41 PM
