2020 F350 Electrical problems
Old May 3, 2022 | 05:17 PM
Tnoble413's Avatar
Tnoble413
Reviewing many posts, I haven't found the same thing going on, but I suspect the culprit to be a wiring harness issue with plugs that don't have dielectric grease in them.
Symptoms:
1) Telescoping mirrors will extend when truck is off and will not retract for several trips.
2) Tailgate opens very sporadically when truck placed in drive. (This is the only symptom I can find addressed)
3) Sliding rear window will open when truck is off after several hours (fantastic on a day like today when we get 1.5 inches of rain...) it will not close for several trips like the mirrors.
4) Communications issue from time to time with ECM/PCM to TCM (the generic trouble code for it).
Note: none of these have ever happened together besides 3 and 4. 3 happens often, but 4 has only happened once so far.
It seems like rain or humidity makes these occur more often, which makes me think wiring harness connectors.
Thoughts?
Old May 3, 2022 | 05:46 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Is this truck out of warranty?
Does sound like a harness issue of some kind.
Old May 3, 2022 | 06:15 PM
Tnoble413's Avatar
Tnoble413
47k miles.
Old May 3, 2022 | 07:02 PM
ToMang07's Avatar
ToMang07
Originally Posted by Tnoble413
47k miles.
I'd being it in for warranty then
Old May 3, 2022 | 07:04 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
47K is outside the bumper to bumper part of the warranty, and that is the part where electrical issues would fall.
Old May 3, 2022 | 07:08 PM
Tnoble413's Avatar
Tnoble413
Yeah, I've replaced several APIMs and other modules since 36.5k... it almost feels like it was engineered to fail... 😔
Old May 3, 2022 | 07:11 PM
fordman19762003's Avatar
fordman19762003
Best thing you can do is get rid of the truck. You'll pull your hair out trying to fix those kinds of electrical gremlins and you might never even find the cause.
Old May 3, 2022 | 07:13 PM
Tnoble413's Avatar
Tnoble413
This thing was great right up until it wasn't lol I've never bought new until this truck and it reminded me why I drove my 2000 7.3 to 400k miles before parting ways with it...
Old May 3, 2022 | 07:35 PM
smikesF350's Avatar
smikesF350
With the loooongggg wait to get a new truck, it might not be such a bad idea to order a tube Ford Dielectric Grease and spend a day under your truck squeezing a dollop into each connector. Might even want to pick up a wiring diagram that lists the location each connector. I have the same truck and I have both items. I just need to put time aside to follow my own advise. I unloaded nice car that started to have gremlins, (like the computer suddenly showing the car was in reverse while driving forward at speed), just to avoid a complete meltdown and full devaluation.
Amazon Amazon
Old May 3, 2022 | 08:40 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
https://www.amazon.com/gp/product/B0...QQVBCCO7&psc=1
Some other name brand of dielectric grease will be EXACTLY the same stuff, and less expensive.
Over 15 bucks for a 3 oz tube, ridiculous!
Old May 3, 2022 | 08:43 PM
Tnoble413's Avatar
Tnoble413
I have plenty of dielectric grease, just need the time to dig in. Thanks all!
Old May 4, 2022 | 06:55 AM
Tnoble413's Avatar
Tnoble413
clearly a wiring harness issue... this morning it's now throwing a DEF fault and limited the speed while also not shutting off the accessory power when the truck is shut off...
Old May 4, 2022 | 07:31 AM
titus_4's Avatar
titus_4
I’d look into an extended warranty, wait a couple months, then take it in.
Old May 4, 2022 | 08:36 AM
niteshiftfromkc's Avatar
niteshiftfromkc
Might watch this from PowerStrokeTechTalk. He shows how the door sills are retaining water and how a wire ended up chafing in two.
Not sure if that could be the problem with your truck or not, but worth a look.
Old May 12, 2022 | 03:31 PM
Tnoble413's Avatar
Tnoble413
Update: it was indeed a faulty harness. The NOX sensor and harness it connects to needs replaced due to corrosion. Of course there was a TSB on it and I'm being told the emissions and powertrain warranty will not cover it. $900
ungerp
Aug 6, 2015 12:58 PM
tommyl
May 26, 2007 07:25 PM
probablecause
May 10, 2006 05:44 PM
wat704
1997 - 2003 F150
Sep 6, 2005 09:28 AM
Forddrof
Aug 14, 2002 02:21 AM
