Boost question
Old Apr 30, 2022 | 11:13 PM
Brooklynh87's Avatar
Brooklynh87
Boost question
2003 F350 7.3
I installed new bellowed up pipes, stage 2 turbo, plennum insterts ,IC tubes and boots.
I'm running a TS6, 4 inch downpipe to 5 inch and a big air filter. I do not yet have a boost leak tester or mechanical Guage. I will be getting them asap but my question for now is the boost readings I'm getting on my CTS3 don't pass 14.. just want to know if I could be making more than that but the PCM is being fooled by the TS6 or something else is wrong? I find it weird that my CTS3 boost only shows other than 0 under heavy load.
I Def hear and feel the turbo kick in and spool up. My connection to the collector and spider are flush.
Old Apr 30, 2022 | 11:39 PM
Wes444's Avatar
Wes444
Without doing the boost leak after replacing so much boost related stuff we'd just be spitballing.
Have you done the 7 turn mod?
With everything stone cold spray the uppipe to manifold connections with soapy water, turn on engine and check the connection for bubbles
Uppipe leak
Old Apr 30, 2022 | 11:43 PM
Brooklynh87
I'll give them a spray tomorrow. What's the 7 turn mod? I'm guessing something to do with the wastegate actuator? Mines set for 35 psi from KC
Old Apr 30, 2022 | 11:44 PM
Wes444's Avatar
Wes444
Yes. So you won't need to do that. Who's tunes are on the TS6?
Old Apr 30, 2022 | 11:50 PM
Brooklynh87
I have no clue. I bought the truck with it.. Stock, High idle, 50hp, 75hp, 100hp & 150hp. I drive it in the 100hp setting without going to crazy and I don't tow. I thought TS's were standard and the Hydras were programmable
Old Apr 30, 2022 | 11:57 PM
Wes444's Avatar
Wes444
You can get the same tunes on either. The TS6 is just older hardware/technology, it requires sending it in for updates/revisions vs Hydra can be changed by you on a laptop by receiving tunes by email from tumer and then you transferring it to the Hydra by a cable. The Hydra also holds more tunes than the TS6, 14 I think.
I use a TS6
I asked who's tunes because some tooners do odd things like SES light on over boost and defuel, vs many turn that factory feature off
Old May 1, 2022 | 12:05 AM
kbeefy's Avatar
kbeefy
Put a mechanical guage on it. Even just a temporary handheld one for troubleshooting. Digital guages are too slow.
Old May 1, 2022 | 12:08 AM
kbeefy's Avatar
kbeefy
My boost is usually pretty low unless I'm towing or getting pretty crazy with it.
I would be uncomfortable driving in +100 all the time without a pyro....
Old May 1, 2022 | 01:06 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
This right here. With mods like these you really need at least an EGT gauge. I'd recommend a 3 or 4 gauge setup. I prefer dedicated analog gauges over data interpreted from the DLC.
Old May 1, 2022 | 01:17 AM
Brooklynh87
I want boost, Pyro, coolant and fuel pressure? What you think. I just have to look up where to put the sensors for coolant and fuel pressure. I know I should have had them by now
Old May 1, 2022 | 01:55 AM
aawlberninf350
It's a Van Gogh
My favorites:
Boost, mechanical with source in AIH plug. Aids diagnosis, fun to watch.
Pyro/EGT plumbed into typical DS exhaust manifold location. Keep you from melting critical reciprocating stuff.
Fuel pressure plumbed after fuel filter. Boring and useless 99% of the time. Then one day driving back from Buffalo Wild Wings the truck starts acting funny, and checking that solves half the diagnosis.
Trans temp if you have an AT. The dash gauge for that is calibrated to keep you ignorant, you need real info.
Coolant temp the dash gauge is fine. It actually reads oil temp but that is a perfectly valid analog for coolant.
Other folks will have different opinions, of course.
Old May 1, 2022 | 07:04 AM
RacinJasonWV's Avatar
RacinJasonWV
My truck came with a standard tuned TS many years ago. I can verify it would only read like 14psi max on a CTS. (Unless my memory is totally lost). The tuning monkeys with the PCM reading for boost. I’ve had another tuner that does that as well. I wouldn’t worry myself over “low” boost reading from the PCM on the CTS if everything seems to be running correctly.
I didn’t catch if you are auto or standard. I’m assuming standard based on your planned gauge selection. If you are auto, I would recommend sending the TS out for new tunes or dropping the money for a Hydra. The TS standard tuning is known to be harsh on transmissions. It shifts harsh and unrefined.
Two most important gauges in my opinion is pyro(EGT) and fuel pressure. Just like aawlbernin said, FP is boring most of the time. Just a very useful diagnostic tool when something goes wrong. Best place for a fuel pressure sensor is bottom passenger side fitting on the back of the fuel bowl. This is POST filter pressure. The easier to access port up top is PRE filter.
Old May 1, 2022 | 07:09 AM
Listor's Avatar
Listor
For you cts3 to read actual boost you will need to add another kit
EDGE EAS Competition Kit - Riffraff Diesel Performance
EAS 100 PSI Pressure Sensor (riffraffdiesel.com)
you may need this as well
Isspro Snubber Kit 7.3L 99-03 (R78828) (riffraffdiesel.com)
otherwise, you are depending on the electronics to determine boost and that's a no-go!
Old May 1, 2022 | 08:42 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
You need to step back, get a baseline and take some notes or screenshots so that you don't have to remember where you started. Your observations of performance may be on par with where you should be, but may not align with your perception of where the level of performance should be.
Stage 2 KC turbo with OEM/AD injectors? Just want to make sure we are clear.
Did you purchase new clamps with the boots are are you reusing the OEM clamps? Specifically the plenum clamps being reused?
If inflation and fuel prices have you in a pinch like a lot of people are, check out the link below.
Link: Brotherhood of the Traveling Boost Detector
With everything stone cold spray the uppipe to manifold connections with soapy water, turn on engine and check the connection for bubbles​​​​​​
^This...
^^This...
^^^This...
My favorites:
^^^^This...
^^^^^This...
Old May 1, 2022 | 11:18 AM
Brooklynh87
I appreciate all the info guys. You pretty much answered all my questions. The boost readings could be wrong due to invalid electronic guages. I'll be getting some mechanical guages along with a boost leak detector to really get to the bottom of this. I guess you answered the question to if I should add then 100psi edge add on or mechanical. Since you say electronic readings are slower I'll prob go with the mechanical.
Yes it's an automatic, and yes its a Stage 2 KC on stock injectors. I replaced the boots with the ones ordered from Riffraf. Clamps are new as well.
Thank you for that link. That's pretty cool you guys do that!
