1978 - 1996 Big Bronco
Quick advice needed, HELP!
Old Nov 8, 2003 | 11:05 AM
Crazyromi's Avatar
Crazyromi
Exclamation Quick advice needed, HELP!
Was planning on taking off my egr valve to clean it today. There is a small green hose that comes into a pipe on the top of the valve. I was pulling that hose off and the thing snapped off about three inches down from the boot. What do I do?? How can I fix this??
Old Nov 8, 2003 | 02:30 PM
BillyBob69's Avatar
BillyBob69
Go to your local parts store and they should have hose splices. A plastic 2 way nipple open at both ends and a couple of hose clamps should work. If it is a hard plasctic hose, then go to your local hardware store and get some plumbers supplies. You can splice the two ends together with a small splice piece and some rubber cement.
Old Nov 8, 2003 | 03:17 PM
Crazyromi's Avatar
Crazyromi
Thanks, I went down to the parts store and grabbed a bunch of vacuum hose and other junk. Spliced them back together. Ugly but it should work.
400inatruck
Sep 2, 2012 09:05 PM
chappys4life
Mar 2, 2012 05:58 AM
F3504ME
16
Jan 8, 2008 04:32 PM
Doug76
Jul 11, 2005 05:27 AM
brian1
May 13, 2001 11:15 AM
