Ground locations
Old Apr 28, 2022 | 01:25 PM
Muskyhunter715's Avatar
Muskyhunter715
Ground locations
Hello all, moving ahead on our father son project truck (94 f150 5.8L 4x4) I was glad to find a compatible injector harness and have that all hooked up and tied in. My next step is to be sure I have all of the appropriate grounds completed. Here is what I have so far….. am I missing any?
1) main ground from battery bolts to frame and smaller connection to core support. End of this wire goes to??? Starter? Block??
2) small ground wire from ECM that attaches to metal bracket that the fender bolts to
3) ground wire from back bolt of manifold (drivers side) which attaches to the firewall.
missing any? Does engine need a ground to the frame too besides the firewall? Does the cab need a ground to the frame?
as always, I appreciate any help that you can share. Many on here have been a huge help with this project and I would be lost without their help!!
thanks
Old Apr 28, 2022 | 01:58 PM
james_1988f250's Avatar
james_1988f250
There are grounds from the hood to the body, grounds on the engine block for the starter and batter, grounds for everything else in various location. Coil should be grounded to engine. No need for a wire from cab to frame, engine to frame, as they are bolted together.
Old Apr 28, 2022 | 02:12 PM
Muskyhunter715
Any idea on the point of the ground from the hood to the body? (I assume firewall)
Old Apr 28, 2022 | 02:34 PM
sandymane's Avatar
sandymane
Keeps static out of the radio.
Old Apr 28, 2022 | 02:42 PM
james_1988f250
Yes, and yes it bolts to the firewall
Old Apr 28, 2022 | 02:52 PM
rla2005's Avatar
rla2005
Subford has some good ground information in this thread: https://www.ford-trucks.com/forums/1...nd-points.html
Old Apr 28, 2022 | 03:14 PM
Muskyhunter715
awesome very helpful. Thanks!! On a seperate note, I also wanted to ask does the PCV valve in the passenger valve cover get hooked up to vacuum from the manifold? It has a vacuum connector on it just above the valve…….. it looks like it does on the vacuum diagram?? Thanks again
Old Apr 28, 2022 | 03:21 PM
rla2005's Avatar
rla2005
Yes the PCV valve is hooked up to manifold vacuum. There was a bulletin (TSB) issued to move the vacuum line from the back of the upper intake to the center vacuum tree. Then move the power brake booster line to the back of the upper intake. So short version is swap the PCV and booster locations.
Old Apr 28, 2022 | 03:58 PM
sandymane's Avatar
sandymane
Randy is that exclusive to any engine or model years? TIA
Old Apr 28, 2022 | 04:10 PM
Muskyhunter715
im not sure the ports in the manifold will support the other hose for the brake booster?? Looks to be quite a bit smaller in diameter. I currently have MAP going to the back outlet
Old Apr 28, 2022 | 05:13 PM
rla2005's Avatar
rla2005
Small block engines.
Old Apr 29, 2022 | 07:05 AM
rla2005's Avatar
rla2005
The PCV and brake booster vacuum lines were the same size on my old 1992 F350 w/5.8L engine. That's why it was an easy swap.
Old Apr 29, 2022 | 07:48 AM
Muskyhunter715
thanks for your help again. Much appreciated!!
Old Dec 27, 2024 | 10:45 AM
Jdff150's Avatar
Jdff150
3rd Gear
No gauges or dash lights
My 96 150 does not have gauges ( just speedometer) working or dash lights.
bulbs are all good, any ideas ty
Old Dec 27, 2024 | 11:02 AM
rla2005's Avatar
rla2005
Originally Posted by Jdff150
any ideas ty
Best suggestion is to start your own new thread instead of tagging onto an old one @Jdff150
