I messed up!
Old Apr 26, 2022 | 09:58 PM
LSO1123's Avatar
LSO1123
I messed up!
I’m doing a motor swap on an 06 F250 I found with a bad motor. When we dropped the good motor/transmission in, we didn’t notice the front trans filter housing was jammed up and it snapped the two trans lines. I have a complete setup from the bad motor that I can swap but my question is, can I get those lines out and back in without raising the motor back up?
Old Apr 27, 2022 | 11:10 AM
Yahiko's Avatar
Yahiko
It will be tight but I think it can be done. Take your time and be sure to
cap or tape the ends so that crap does not get into the lines.
Old Apr 27, 2022 | 11:39 PM
LSO1123's Avatar
LSO1123
Yeah I got the broken ones out tonight. I tried to feed the good ones back thru between the cross member and the oil pan but I couldn’t do it by myself. I need somebody to stand in front of the truck and feed the lines in while I’m under it working then thru. My buddy will be helping me tomorrow evening. That’s the last thing I need to button up before I lower the cab back down.
Old Apr 28, 2022 | 05:43 AM
TooManyToys.'s Avatar
TooManyToys.
You can loosen the four engine mount bolts and jack the engine up an inch or two to get you more room.
Old May 2, 2022 | 10:42 PM
LSO1123's Avatar
LSO1123
Thats exactly what we did. Used the chain hoist to raise the engine up and dropped the lines right in. Cab is up and running now.
cworley250sd
1997 - 2003 F150
Jan 20, 2018 12:45 PM
mikemathis18
Jan 22, 2011 06:36 PM
redo f-1504x4
Oct 30, 2003 12:46 PM
