Towing Heavy
Old Apr 22, 2022 | 09:36 PM
DSLTRK60's Avatar
DSLTRK60
Towing Heavy
How heavy is too heavy for the 6.2?
Truck pulled this load fine from Henderson NV, but only did 45 up the grade out of Primm. All temps stayed in range and cool, fan did come on up grade. Was pulling 4500 rpm in 2nd a few times.
Overall, truck impressed me, especially the transmission.
The weight ticket axle weights are off btw.
Old Apr 23, 2022 | 04:07 AM
OverheadCram's Avatar
OverheadCram
Nice workout for the 6.2L. Ive got two 2022 with the 10spd ordered and cant wait to get them working.
My 2013 6.2L has 153k miles and 90% is towing 23-24k gross. Been a problem free reliable truck I plan to keep well past 300k miles.
Old Apr 23, 2022 | 06:19 AM
senix's Avatar
senix
I think you are fine, hard to tell with a messed up ticket but most likely your axles are within the capacity so no issues, but hope you have a class A as it does appear you are over 26K.
Old Apr 23, 2022 | 07:44 AM
drj564's Avatar
drj564
1120 on the rear truck axle and 10K on front? That does not seem right.
EDIT: Never mind, just saw the last sentence.
Old Apr 23, 2022 | 08:10 AM
shawnee1's Avatar
shawnee1
I'm wondering why a certified scale weight ticket has inaccurate axle weights. Seems like it defeats the purpose of being weighed on certified scales. If the axle weights are known to be incorrect, how can you be sure the total weight is correct. Is this an acceptable occurrence with certified scales?
Old Apr 23, 2022 | 08:17 AM
RidgwaySD's Avatar
RidgwaySD
So it is clear to me some have never been on the scales... It is pretty easy to be off on the axle pads set up for larger rigs. Looks to me like he just pulled up a little too far. Still gives and accurate total.
Old Apr 23, 2022 | 08:20 AM
chadstickpoindexter's Avatar
chadstickpoindexter
I've been on a few CAT scales set up for "larger rigs" and even with my shorter set ups it hasn't been a problem to correctly have each axle on the appropriate scale.
Old Apr 23, 2022 | 08:55 AM
RidgwaySD's Avatar
RidgwaySD
I haven't had any problem either but then I wanted to make sure I had axle weights. It is as easy to do it wrong as it is to do it right but it seems like the total was the goal so the OP reached it. The rest of the nitpicking...OMG
Old Apr 23, 2022 | 09:21 AM
DSLTRK60's Avatar
DSLTRK60
I think I pulled up too far as well, coupled with the short regular cab, so it threw off the axle weights.
Old Apr 23, 2022 | 04:51 PM
RidgwaySD's Avatar
RidgwaySD
If I had to guess I would say you had about 4000 front axle, 7000 rear axle.
With the mini ex on the gooseneck I am probably about 24k and my gas truck pulls it around just fine too.
Old Apr 23, 2022 | 05:23 PM
scraprat's Avatar
scraprat
Top Answer: 5
A quick glance at the wheels (axles) to be sure they're on the right scale sections when using the cat scales before hitting the call button.
Rutcutter
Jun 29, 2020 08:46 PM
98ramtough
Feb 8, 2020 10:31 AM
giant futon
6.2L V8
83
Apr 27, 2018 05:04 PM
Slavoise
Jul 15, 2017 01:31 PM
Skandocious
43
Jun 26, 2007 11:11 AM
