Low power issue
Old May 7, 2022 | 11:19 PM
  #31
alaskapilot95's Avatar
alaskapilot95
Originally Posted by Agate Flats
I would install a new Motorcraft IPR before investing in injectors. Best case it fixes you problem, worst case you now have a spare. A new LPOP might not be a bad idea either.
I have tried an alternative IPR and it did the same thing so it doesn’t make me think IPR especially since it’s making 3,800psi deadheaded
Old May 7, 2022 | 11:59 PM
  #32
Agate Flats's Avatar
Agate Flats
Sorry, I missed that part.
Old May 8, 2022 | 07:04 AM
  #33
ESwift's Avatar
ESwift
CNCFAB
So hpop seems good. Have you deadheaded each head individually yet? My guess is injector oring issues, may have some minor leaking starting. Or just tired injectors
Old May 8, 2022 | 07:58 AM
  #34
RacinJasonWV's Avatar
RacinJasonWV
Link to instructions for the process.
https://www.ford-trucks.com/forums/1...l#post20397196
Old May 8, 2022 | 07:46 PM
  #35
udsuth78's Avatar
udsuth78
Is performance still down? No change in WOT numbers at all?
Old May 9, 2022 | 12:11 AM
  #36
alaskapilot95
That is what I am thinking now. Since I replaced the external o rings and it didn't change the results im suspecting internal injector o rings. If I have the injectors hooked up and unplug them to prevent them from firing then I get 2300psi through the ICP gauge. I know the guage will read higher as I can make it read 2800 by letting off on the throttle some at times.
No change in number after replacing the o rings. It did make fuel pressure more stable around 62-64psi as the lower o rings were shot on the injectors. Still seems to be lacking power and has same readings on numbers.
Old May 9, 2022 | 08:24 AM
  #37
ESwift's Avatar
ESwift
CNCFAB
I would be interested to see what psi the pump deadhead at with oil up to operating temps
Old May 9, 2022 | 07:14 PM
  #38
alaskapilot95
I might try to do that one of these days just to make sure it doesn't die off when it gets warm.
Old May 10, 2022 | 10:22 PM
  #39
alaskapilot95
Alright did a bunch of testing tonight. I forgot all my testing before was in 1023's custom tunes on the Cummins killer tune. Now I am leaning towards my hpop just not being able to stay caught up to the tune. So heres the test in stock tune
Heres the run in Cummins Killer Tune (1023)
Here is an idle video after I got home.
And here is my HPOP test after running so the engine was warm.
After all this I think my hpop is getting worn out and can't keep up with the tunes. It might make pressure at idle and the deadhead test but I think the flow is lacking and it shows in the high power tunes. THe idle sounds clean and no vibrations which makes me lean away from injectors. What do you guys think?
Old May 10, 2022 | 11:00 PM
  #40
alaskapilot95
Pulled out my old android phone and ran a contribution test and buzz test. Buzz tested sounded fine but it through a code for cylinder 3 and 8 and also injector high side open bank 1 and 2. Now it sounds injector related.....I know 8 can be always happen due to the LL injector but 3 is unsual I think.
Old May 10, 2022 | 11:10 PM
  #41
Agate Flats
My truck had cylinder 3 and 8 codes on the CCT before my injectors were replaced 15k ago. It still throws the same codes most of the time on the CCT. I wouldn't make any decisions based solely on those CCT results.
Old May 12, 2022 | 12:05 AM
  #42
alaskapilot95
Hmm ok. I do have a HPOP off my old engine that still seemed to work fine but the cylinders were worn out. I could try using that hpop on this engine and that will give me an idea about HPOP or injectors.
Hoosier 7.3
Jul 3, 2015 11:07 PM
sportsdad
13
Jun 8, 2014 05:06 AM
dillehay
Jan 30, 2013 08:29 AM
kawcrasher
30
Nov 20, 2011 10:14 PM
ColoradoFordBoys
20
Jun 19, 2011 01:01 PM
