Another Priming Question
Old Apr 22, 2022 | 06:19 PM
Seq23's Avatar
Seq23
Trailering
Just picked up a new to me 61 F100 with a 351w. Previous owner put new top end on a junkyard block and never fired it. I'm priming the oil and only getting oil to the #2 exhaust rocker (lots) I see a little oil pooling in the #5 intake​​​​rocker as well but that's it. Getting 50#'s on the guage. I've rotated the crank, still no change. Even got a new drill thinking maybe the RPMs were too slow on my old tire d one. Do I need to pull the intake and timing cover to check for a missing plug or just fire it up and see what happens?
Old Apr 23, 2022 | 09:08 PM
Seq23's Avatar
Seq23
Trailering
Update: I pulled the intake and the #2 exhaust rocker is bad. New ones on the way.
Old Apr 24, 2022 | 08:37 AM
DaveMcLain's Avatar
DaveMcLain
I never use a drill to prime the oiling system I just turn the pump by hand using a 1/4 drive speed handle. The pump can be turned really slowly and still maintain reasonable oil pressure. With that said sometimes mostly depending on the lifters it can take a REALLY long time until all 16 rocker arms flow oil.
Old Apr 24, 2022 | 11:11 AM
Seq23's Avatar
Seq23
Trailering
I pulled the intake. It's a bad lifter. New ones on the way.
Old Apr 24, 2022 | 11:46 AM
DaveMcLain's Avatar
DaveMcLain
What's bad about it?
Old May 16, 2022 | 08:32 PM
Seq23's Avatar
Seq23
Trailering
Well, I'm back to square one. Still only getting oil to the #4 intake rocker. Any thoughts? I pulled the intake and everything looked fine. About to pull the timing cover. I'd think of any plugs were missing I wouldn't be getting much oil to the rockers at all but #4 is a gusher and nothing to the rest.
Old May 17, 2022 | 05:36 AM
DaveMcLain's Avatar
DaveMcLain
Bar the engine around and keep cranking the pump till all of them oil.
Old May 17, 2022 | 08:45 AM
Seq23's Avatar
Seq23
Trailering
I've done that already, no difference. After I replaced the lifters, I started to get oil pooling in the rockers so figured I was good to go and started it. Now at Idle up to 2k I'm only getting oil to the #4 intake.
Old May 17, 2022 | 08:50 AM
DaveMcLain's Avatar
DaveMcLain
How long did you run the engine?
Old May 17, 2022 | 11:36 AM
Seq23's Avatar
Seq23
Trailering
20 minutes +/-.
Old May 17, 2022 | 12:02 PM
DaveMcLain's Avatar
DaveMcLain
It usually only takes about 10psi oil pressure to get a hydraulic lifter to operate. You say that only the #4 intake valve is getting oil so that one's the 2nd from the rear on the main galley in a 460. It seems like if a plug was out at the front or at the crossover and dumping pressure that it would be obvious. What's the oil pressure?
Old May 17, 2022 | 12:25 PM
Seq23's Avatar
Seq23
Trailering
50#'s. I meant the #3 intake rocker, not #4.
Old May 17, 2022 | 01:23 PM
DaveMcLain's Avatar
DaveMcLain
After running the engine for 20 minutes the rockers must have been squeaking. I wonder if it could possibly have a lifter for an FE instead of the right one for a 460?
Old May 17, 2022 | 02:04 PM
Seq23's Avatar
Seq23
Trailering
Its a 351W, not a 460. I swapped the lifters and no change. I'll double check the box for the new lifters but I'm pretty sure they are the right ones.
Old May 17, 2022 | 03:28 PM
DaveMcLain's Avatar
DaveMcLain
sorry about that... They do have a single passage that feeds both lifter galleys at the rear of the block. It seems pretty unlikely that it would become restricted unless it was an engine that somebody did that for a race application.
