Does anybody make an intake...
Old Apr 20, 2022 | 07:38 AM
Fuzzpuss's Avatar
Fuzzpuss
...that doesn't squish the wire harnesses?
Old Apr 20, 2022 | 08:55 AM
LCR's Avatar
LCR
S&B would probably be the only aftermarket filter is look at.
Old Apr 20, 2022 | 09:08 AM
Fuzzpuss's Avatar
Fuzzpuss
Speaking from personal experience?
Old Apr 20, 2022 | 09:13 AM
TooManyToys.'s Avatar
TooManyToys.
Where are you talking about Chris?
Old Apr 20, 2022 | 09:27 AM
Fuzzpuss's Avatar
Fuzzpuss
Between the filter box and turbo. Every time I mount that pipe to the turbo it makes me cringe. It sits right on top of my (fairly new) main engine harness above the valve cover.
Old Apr 21, 2022 | 01:06 PM
Yahiko's Avatar
Yahiko
That is the one that Ed told me to get if I wanted to go aftermarket filter. The PoO of my truck
had put in some sort a crap gauze filter. I was able to find the parts for a stock install at the scrap yard.
EDIT : Idea time. You could put some large split loom over the harness where it crosses under the intake for a little added protection.
Old Apr 21, 2022 | 01:42 PM
FiveOJester's Avatar
FiveOJester
Does anyone have this issue with the stock intake? I pulled my turbo last fall and found that the stock turbo inlet tube had rubbed all the way thru the loom on the outside of the wiring harness. Fortunately had not gotten thru any wiring insulation. I added a large split loom over the top to protect it.
Old Apr 23, 2022 | 01:45 PM
LCR's Avatar
LCR
I like that they do ISO testing on each intake assembly and post the results, not just for the filter itself.
There’s a mile long hill back home I used to drive every day, and everyday on cruise control the truck would downshift to get up. I installed that S&B and the truck never again downshifted again going up that hill. So with my data point of 1 their filters actually work.
Old Apr 24, 2022 | 03:18 AM
Hartwig's Avatar
Hartwig
I also have the S&B installed, works flawlessly. I like that I can check the filter element through the acrylic cover.
However, I have installed the dry filter element. In my opinion, the oiled filter element has a higher air flow rate, but poorer filter performance.
Old Apr 24, 2022 | 07:47 AM
TooManyToys.
Every 100k, I change the stock filter if it needs it or not. Twice, it hasn't. However, my high throttle time is very limited.
Old Apr 24, 2022 | 09:32 AM
Fuzzpuss's Avatar
Fuzzpuss
Is there any clearance between the pipe to the turbo and the main engine harness?
Old Apr 24, 2022 | 09:45 AM
Hartwig's Avatar
Hartwig
I have no problems with the wiring harness, on my truck nothing is pressed together at this point. But I have also installed a CCV reroute. This eliminates the hose from the valve cover driver side to the intake tube in front of the turbo.
Old Apr 24, 2022 | 07:44 PM
Fuzzpuss's Avatar
Fuzzpuss
I might have to put one on my wish list. I had the intake off today and noticed wear on the impeller of my four month old turbo. One of the blades has white paint on it (a wear indicator?) that is worn on the edge. I have always suspected the back plate of the stock set-up that warps on the engine side was leaking unfiltered air. Why Ford didn't put retainer clips on that side like they did on the outside is anyone's guess, but I've now had three stock intakes between my two trucks and they all warped in the same manner. Drives me crazy....along with the lack of harness clearance.
Old Apr 24, 2022 | 07:51 PM
TooManyToys.
I once put screws in that lip to keep it looking tighter. You can plug both ends and pull a vacuum through the filter minder port to see if it leaks.
Old Apr 24, 2022 | 07:58 PM
TooManyToys.
I fired up the old Vaio computer where I have old photos from the pictorials I used to have on Webshots, 2001-2005. No narrative from then, but my pictures.
