Door/Body Panel Interchange
Once l got it into the garage, l noticed that the passenger door is a little more rumpled than l remembered... seems like a replacement door is in order..
An 85, regular cab w manual locks/windows is what l need, but will a door from a Bronco work? Are the Super Cab (extended cab) doors the same? (some makes use a shorter door). What year range, 80-86?
electric, 2 mounting points mirror (4 bolts) Right
electric, 2 mounting points mirror (4 bolts) Left
electric, 3 mounting points mirror (3 bolts) Right
electric, 3 mounting points mirror (3 bolts) Left
electric, pedestal mirror (2 bolts) Right
electric, pedestal mirror (2 bolts) Left
manual, 2 mounting points mirror (4 bolts) Right
manual, 2 mounting points mirror (4 bolts) Left
manual, 3 mounting points mirror (3 bolts) Right
manual, 3 mounting points mirror (3 bolts) Left
manual, pedestal mirror (2 bolts) Right
manual, pedestal mirror (2 bolts) Left
When sellers specify "manual" or "electric" l assume they're referring to window and locks... ? Does it matter that much if I can just swap-in my OEM (manual) gear and panels, or is there a significant difference? I'm only just now starting to dig into this thing, so l haven't even had the door panels off yet.
The daydreaming phase has run it's course... time to spin wrenches.
BTW, car-part.com confirmed that my local yard, and a couple within 50 miles, have what I'm looking for... it'll save me from making a bunch of useless phone calls. Hell, it looks like my local yard still has the 83 that l pulled (underhood) parts off of last year.
