1978 - 1996 Big Bronco
locking hubs loose
Old Nov 7, 2003 | 10:11 PM
yukonhighboy's Avatar
yukonhighboy
Question locking hubs loose
Greetings,
I noticed the other day that both of the hubs on my bronco seem loose. There is about 1/16" gap between the chrome housing and the rotor(?). this gap gets a little bigger when the hubs are locked. tried tightening the allen screws but they are already tight. is this something to be concerned about or is it normal? this truck is new to me and i'm ironing out the bugs one at a time.
tia
Bob
Old Nov 7, 2003 | 11:01 PM
red bud's Avatar
red bud
I've got the same problem, but if it matters, with the Warn hubs. About the same 1/16th of an inch. Tried tightening, but still loose. You find out what it is, post back please.
Old Nov 8, 2003 | 12:09 AM
yukonhighboy
hey red bud,
how long have yours been like this. has it caused you problems?
Old Nov 8, 2003 | 09:47 AM
BillyBob69's Avatar
BillyBob69
Sounds to me like the spindle nut isnt tightened down far enough. Raise the wheel off the ground and see if you have any play in it top to bottom. If you do it could possibly be fixed by removing your hub assembly and tightening the spindle nuts a bit, (Check a manual for factory specs), or since you have it that far anyway, replace your bearings. They may also be the cause. Anothe thing to look for is the assymbly of the hub itself. Open it up and check all your parts. May find the prob without getting expensive.
Old Nov 8, 2003 | 05:55 PM
red bud's Avatar
red bud
No problems with it this way, but I haven't driven it in the snow yet. I'm afraid the salt and water will get in there and mess everything up.
Old Nov 8, 2003 | 08:07 PM
steve83's Avatar
steve83
I think the large C-ring that holds the lock body in the hub has come out of its groove. Look through the other pictures in the Brakes & Hubs photo album in my signature link. Yours don't look exactly like this, but the C-ring is the same.
Old Nov 8, 2003 | 09:00 PM
yukonhighboy
what do you think is the likelyhood that both sides would have come out and do you think anything will get trashed if i din't get on it right away?
Old Nov 8, 2003 | 11:22 PM
steve83's Avatar
steve83
If you hit something with one hub, it's possible the other hub hit something, too. But it would only take a couple of seconds to check - just pull the cap screws and look inside. If the C-ring falls out when you pull the cap off, than you've found the problem. If it's still in place, I'd guess the screws are too long.
GaMachinist
Jun 29, 2014 04:00 PM
JonDavis1984
Feb 1, 2014 12:29 PM
Dyllan78
Dec 11, 2013 05:48 PM
