2022 climate control problem
Old Apr 14, 2022 | 11:07 PM
cat-alac's Avatar
cat-alac
Hoping someone has some insight as to what I have going on, have a 2022 plat 6.7 cc srw 350, my climate temp control seems to have gone wonky. Outside temps have been 25-60 last couple weeks:
If I set inside temp to 72 (synced both sides)and run on panel vents only fan speed 3-5 all works ok.
If I set to 72 (synced both sides) with panel vents and floor vents together fan 3-5 the floor vent and passenger center vent is warmer air than the drivers vents which are noticeably cooler. And to be comfortable I have to put temp down to 62 degrees to keep same interior feel as panel only set at 72.
Jimmygunz3
Dec 17, 2008 10:05 PM
lariatf150
2004 - 2008 F150
Sep 4, 2007 07:03 AM
Zukster
1978 - 1996 Big Bronco
May 21, 2003 09:31 PM
TexanF250
Mar 7, 2002 09:10 AM
