1966 F100 Engine code de-code
Old Apr 11, 2022 | 02:00 PM
mbapsu's Avatar
mbapsu
Hi folks,
I am new to this site.
I have a 1966 F100. The VIN plate is F10AN802005 which I believe indicates a 240 cid In-line 6-cylinder motor. The previous owner insisted that the truck had a 300 cid in-line 6. The stamping on the motor block is 05AE-6015-F and 5D20 -- does this engine code identify the motor size?
Old Apr 11, 2022 | 03:07 PM
TA455HO's Avatar
TA455HO
Lead Gopher
802005 is early January 1966. The 5D20 is April 20th, 1965. Engine date code is likely too old to be the one that came in the truck. The C5AE-6015-F is common between the 240 and 300 so that won't help. But, measure the stoke through a spark plug hole using a dowel marked at top dead center and bottom dead center. 240 is 3.18 and 300 is 3.98. Should be easy to tell which it is.
Old Apr 12, 2022 | 07:54 AM
mbapsu's Avatar
mbapsu
Thanks TA455HO. I don't have the engine torn apart, so I will not be able to measure TDC and BDC.
Old Apr 12, 2022 | 07:58 AM
1966F100SC's Avatar
1966F100SC
Use a dowel or coat hanger in the spark plug hole. No need to rear engine down.
greenmachine319
Dec 17, 2010 11:51 PM
becca33308
1961 - 1963 F100 Unibody
Sep 1, 2010 04:12 PM
northeaster79
May 22, 2009 07:00 AM
jhooch
Mar 5, 2007 12:39 AM
snipa
Oct 28, 2004 10:03 AM
