*new* 06 Exploder 4.0
Old Apr 8, 2022 | 09:33 PM
stephen.osborne1's Avatar
stephen.osborne1
Just picked up a 06 Explorer for my daughter. The 04 f150 she's currently driving is horrible on gas for an 18 year old so we figured the 4.0 should be a little better.
Picked this one up for a song but it needs work. Going to pull the motor and have a buddy do the timing set... It runs but the front chain smacked a hole in the driver's side cam cover.
Old Apr 9, 2022 | 03:55 AM
DILLARD000's Avatar
DILLARD000
Good looking 2006 Explorer!
Let us know what TimingComponents get replaced & what brand used (MotorCraft, Cloyes, Melling...)
While the V6~4.0L~SOHC engine is out, also consider
~ renewing the RearOilSeal.
~ renewing\upgrading the OilPump.
~ renewing the PCVValve+HoseAssembly.
~ renewing the Plugs+Wires+OxSensors.
~ upgrading the junk Plastic ThermostatHousing to an Aluminum version.
~ upgrading the junk PlasticTanked 2RowCore Radiator to an AllAluminum 3or4RowCore.
~ renewing the RadiatorCap+CoolingPump+CoolingHoses+CoolingFan+Fa nClutch+SerpBelt+BeltTensioner
~ Tranny PanDrop, new ValveBody Solenoids+BondedGasket+ServoORings+ServoGasket, new Filter, new PanGasket, new MerconV, Band adjust.
~ upgrading to a 2ndParallel\Larger TransCooler.
Old Apr 9, 2022 | 09:20 AM
stephen.osborne1
All good advice. Thank you
Old Apr 10, 2022 | 07:56 PM
stephen.osborne1
Got the motor pulled today. Took about 6 hours.
Old Apr 11, 2022 | 03:02 PM
Denny333's Avatar
Denny333
Good to see more ladies working on their vehicles, gives me inspiration! But, don't be surprised if your gas mileage doesn't improve by much, the 5 liter and 4 liter are similar for mileage. Did you take training for mechanics or is it simply experience! I'm a senior gal learning what I can DIY on my 98 XLT. Good job on yours!
Old Apr 11, 2022 | 07:01 PM
stephen.osborne1
That's my wife and daughter... Lots of experience mainly. Youtube videos can teach you anything. The 5.4 in my daughter truck gets about 13 or 14 combined. Still better than my Raptor or the 390 in the 66, but the kid can't afford poor mileage like I can... This explorer should get at least a few more mpgs. If not, we can flip it.
Ordered the full timing kit and gaskets today. Went with Cloyes and felpro. Should be here tomorrow.
Old Apr 12, 2022 | 01:44 PM
stephen.osborne1
Gaskets came in today. Timing set got stuck in salt lake. Should be here tomorrow. Was planning to drop off the motor at my buddy's shop for him to do the timing set but now he wants to do it at my place so we're planning to offload it back into my shop later today.
Old Apr 16, 2022 | 10:47 AM
stephen.osborne1
My buddy made it over last night. We started tear down and decided to go ahead and pull the heads. His machine shop in town can get a valve job done with the new seals included in the gasket set installed this morning for a few hundred bucks. Might as well...
The daughter and I are headed to a junk yard this morning to find a cam cover and possibly an intake manifold.
Old Apr 16, 2022 | 02:01 PM
stephen.osborne1
The daughter and I went to the junk yard and found an intake manifold without a broken pcv nipple and driver side cam cover. Even got the throttle body all for $35.
Heads won't be done until Monday so have some time to clean parts.
Old Apr 17, 2022 | 03:06 PM
explorerdriver's Avatar
explorerdriver
Good you have access to a pick and pull!
If the SOHC engine issues are addressed you should be good for a very long time.
The V6 trans is so so, but not the worst year.
Old Apr 17, 2022 | 03:39 PM
stephen.osborne1
we are essentially replacing the entire valvetrain and all seals. Should be a pretty reliable truck for her.
Old Apr 18, 2022 | 07:08 PM
explorerdriver
I think those engines eat harmonic balancers, so give it a second look.
Old Apr 18, 2022 | 08:33 PM
DILLARD000's Avatar
DILLARD000
Good to be teaching your daughter how to get things done;
she'll be a force to be reckoned with.
Old Apr 22, 2022 | 10:08 PM
stephen.osborne1
More teardown today. My back is out again so the girls helped my buddy. Decided to order a high volume oil pump after seeing all the guide chunks in the oil pan and pickup.
Old May 2, 2022 | 05:02 PM
stephen.osborne1
Started the timing install yesterday. My buddy is coming back tonight to help finish putting on heads, rear timing set, new HV Melling oil pump, then rear main, etc.
we also spent a lot of time steam cleaning the interior. Took out the back seat and cleaned the carpet and surroundings. Still have the front seats to do. It was GROSS...
