*new* 06 Exploder 4.0
Old May 5, 2022 | 03:04 PM
stephen.osborne1's Avatar
stephen.osborne1
Heads installed, timing chains in place. New rear main. Tonight planning to finish with cams, lifters, etc. New oil pump and pan installed
Old May 8, 2022 | 05:26 PM
stephen.osborne1
Got the motor pretty much all back together. Plan to stick it back into place this week as time allows.
Old May 18, 2022 | 10:09 PM
stephen.osborne1
Got the motor stuck in place and all buttoned up Sunday. Took about 10 hours. Started right up and sounded smooth. Test drive the next day threw all kinds of codes, erratic running, etc. Swapped in the original egr valve and found some wires the PO had stripped and taped with duct tape. Think they were touching each other, causing issues. We cut, soldered, and heat shrank them. Test drive indicated no more issues. No CEL.
We also replaced the trans filter and filled the trans with fresh cherry juice.
shocks24
Nov 24, 2018 04:52 PM
82_F100_300Six
Modular V8 (4.6L, 5.4L)
Mar 18, 2017 02:46 PM
fordnut forever
Nebraska Chapter
Nov 21, 2008 04:17 PM
Unit38
Sep 22, 2006 04:37 PM
