Shut down process
Old Apr 6, 2022 | 08:27 PM
Hunter3006's Avatar
Hunter3006
Shut down process
Hi everyone, two weeks ago I had a check engine light codes P20BA (def heater) and P0401 (EGR cooler Insufficient flow). I replaced the def heater and a couple of days later the check engine light went out for about a week and a half. Now the P0401 code is back. So I assume that a I have to replace the EGR cooler? Also will the P0401 code cause the truck to start the shut down process?
Old Apr 7, 2022 | 05:18 AM
Overkill2's Avatar
Overkill2
Hey good morning.
What year truck and how many miles? Prior problems at all? More info will help others give suggestions.
Old Apr 7, 2022 | 06:14 AM
Hunter3006's Avatar
Hunter3006
2012, 205000 miles, 6.7
Old Apr 7, 2022 | 07:09 AM
Hunter3006's Avatar
Hunter3006
6.7 diesel
Old Apr 7, 2022 | 07:16 AM
kper05's Avatar
kper05
Based on my experience, sporadic P0401 is the early stages of the EGR cooler plugging issue. Active P0401 will cause engine derate but with the two months I had the issue, it didn't cause a shutdown condition. Normal daily driving you won't notice the derate much but put it to work and it has an obvious lack of power, especially when you reach a hill. However, the truck wasn't healthy and didn't sound normal, best to just resolve the issue as soon as you can get parts.
205k miles is a good run if this is the original cooler. Unfortunately, it's an unlisted maintenance item just with various mileage results.
Old Apr 7, 2022 | 07:29 AM
Hunter3006's Avatar
Hunter3006
As for as i know it's the original cooler. I'm the third owner, my Dad being the 2nd. He bought it at 124000 miles.
Old Apr 7, 2022 | 12:54 PM
doczenith1's Avatar
doczenith1
My EGR cooler clogged at 58,000 miles (and 61 months). I had a lot of short trips unloaded during those miles so I was not all that surprised. I was able to get it covered under the 8/80 emissions warranty. If I remember correctly the bill would have been around $2,000.
Old Apr 9, 2022 | 03:19 PM
Hunter3006's Avatar
Hunter3006
Thanks for everyone's input. The CEL is coming on and off sporadically as kper05 says. i guess I'll have to either replace it or clean it soon.
Old Apr 9, 2022 | 06:47 PM
senix's Avatar
senix
Start soaking those bolts with PB Blaster now.
Birdhunter23
May 1, 2021 10:46 AM
Blwest
6.7L Power Stroke Diesel
Jul 25, 2020 09:56 PM
Stevem4134
May 10, 2019 08:33 AM
diesel stopper
Mar 16, 2016 01:33 PM
hittingguru
Aug 7, 2011 06:18 PM
