Brake upgrade time
Old Apr 7, 2022 | 01:13 PM
99.5_Superduty's Avatar
99.5_Superduty
Didnt read the thread, but yes you’ll need F450/550 knuckles to run the larger rotors and calipers. This will also require larger wheels (20”?). Otherwise, it should be a bolt-on swap (your axle shafts, hub bearings, locking hubs, etc should still work)
are you able to keep 8x170 bolt pattern?
What size are the rotors?
Old Apr 7, 2022 | 01:32 PM
RA101725's Avatar
RA101725
Banned
I don’t think the rotors are compatible either. Different (larger) bolt pattern for the 450/550 that use a 19.5” wheel. It’s 8x225 or something like that. Swapping a junkyard front axle with the right ratio and all the wheel end hardware included would probably be easiest way to do it on a 4x4.
Old Apr 7, 2022 | 05:55 PM
SkySkiJason's Avatar
SkySkiJason
Yes. The rotors are 8x170 and fit the same unit bearings as the F250/350. They are larger diameter rotors than F250/350.
on edit: that’s the point of this swap. Bigger rotors and bigger calipers. I’ll try to pull out some F450/550 calipers and rotors and F250/350 to compare.
The F450/550 have adapters for dually wheels that convert to the larger diameter bolt pattern.
Old Apr 7, 2022 | 06:01 PM
SkySkiJason
You won’t find F450/550 with the 3.73 and 4.10 gear ratios commonly found under F250/350’s. 4.30 is rare and 4.88/5.38 is common.
All F450/550 will be 19.5” wheels and dually’s.
Old Apr 7, 2022 | 06:07 PM
SkySkiJason
Which pads are those? the Akebono? I'm probably going for the Motorcraft blue pads on the front next. For the price they look like the winners. Not parts store crap but not the ridiculously overpriced EBC stuff either.
EBC Yellowstuff pads stop better than anything else. No comparison to anything over the counter....
Look for these under ‘used’ on the amazon. Usually just returns and 40% or more off retail. Often not even damaged packaging OR opened.
Old Apr 7, 2022 | 06:08 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
Another vote for the SSBC calipers. They will stop some big ol tires let me tell ya.
Old Apr 7, 2022 | 08:18 PM
RA101725's Avatar
RA101725
Banned
Oh. Learn something new every day. That could be a worthwhile swap then for the 4x4 trucks. A lot of guys already have 19 or 20 inch wheels to fit over them. 2wd guys with the 1-piece hub/rotor units on the twin-I beam front are definitely out of luck since the 450/550 2wd didn't use those.
After looking around on the Rock auto catalog it looks like you jump from a 13" rotor on the front to a 14.5". What I can't seem to figure out is what the size difference is between the rear rotors on a 450/550 and 350 DRW like I have but that's getting a little beyond the scope.
Old Apr 8, 2022 | 05:15 AM
FordTruckNoob's Avatar
FordTruckNoob
The factory rear brakes are probably adequate. The majority of the braking comes from the front wheels anyway.
If you are going to do 20” wheels, there’s an outfit that does a Wilwood upgrade. I’ll see if I can find it again.
Old Apr 8, 2022 | 06:03 AM
ESwift's Avatar
ESwift
CNCFAB
I feel like they would be a good, easy bolt on option for heavy towing. You have them? Happy so far?
Old Apr 8, 2022 | 06:46 AM
SkySkiJason
Ive read that DRW F350 can bolt on the bigger F450/550 hubs and rotors and the bigger calipers bolt up??? But, I’ve never had a chance to check on that. I’ve got an F550 in the driveway right now, maybe I can attempt to measure caliper mounting points to compare to the smaller trucks.
Since we have a single reservoir MC, and no proportioning valve, our front and rear brakes receive equal pressure. The front brakes do more work because bigger caliper pistons and pads. This makes we wonder if only upgrading the front calipers would create more of a tendency to lock up the front brakes????
I can tell you with certainty that an F450/550 with EBC Yellowstuff pads that are fully broken in will stop a HEAVY truck with AUTHORITY. I have a few customers running those trucks around here (mountains) using them on service trucks and tree chipper trucks and they consider the ‘good pads’ a safety feature.
Old Apr 8, 2022 | 07:18 AM
99.5_Superduty
@SkySkiJason as usual, thank you for the great info. It sounds like a worthy upgrade.
I recently swapped my 99 to coil springs and went with 2015 parts from the knuckles out. That yielded me a 14.3" rotor. At the same time i went from a 285 to a 37" tire. The braking performance is amazing compared to the stock 99.5 braking with performance friction pads. I was able to use a 17" wheel.
Had i not done the above conversion, the F450 upgrade you describe seems like a no brainer for somebody after markedly better braking.
Old Apr 8, 2022 | 08:26 AM
RA101725's Avatar
RA101725
Banned
I'd be curious to compare the differences between a 350 DRW and 450 rear axle as far as the brake hardware and hub. (Same 8x170 bolt pattern on the rotor and hub with a wheel adapter like on the front or is it all 8x225?)
Does the 450/550 have a different type of MC with a proportioning valve? In stock form I can say the brakes were nothing impressive on this era of truck. Barely adequate on a 250/350. Never drove a 450/550 of this era to say if they were noticeably better.
So they do make pads for the 450/550 calipers also? Riff-Raff doesn't advertise them but it must be a different part number.
Old Apr 8, 2022 | 10:24 AM
  #28
SkySkiJason
The rear axle/hubs will not be 8x170 on the F450/550.
I think MC is the same, but larger calipers/rotors/pads increases stopping power.
Yes, different part number because they’re BIGGER/different pads.
Old Apr 9, 2022 | 03:37 AM
  #29
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I have the SSBC V8 calipers and count me as a fan. Functional improvement over stock.
But it's not equivalent to larger rotors. That's where major braking improvement happens. Granted my experience here is just a Subaru Forester, but I can tell you another inch of front disc is awesome. Swapped 2007 rotors/wheels/caliper brackets onto a 2001, too easy.
Hoping this F450 big brake swap happens just so I can be a fly on the wall. Wish it was easy as the Subie.
Old Apr 9, 2022 | 07:34 AM
  #30
F0rdc0wb0y's Avatar
F0rdc0wb0y
I have a set on two of my trucks. They stop so much better than the factory calipers. When I put 35’s on one of the trucks, I lost confidence in its ability to stop quickly in an emergency. The SSBC’s fixed that.
