Knock Sensor
Old Apr 4, 2022 | 03:56 PM
llama's Avatar
llama
Knock Sensor
I am replacing the heads and cam on my 94 5.0. Along the lines of since I am already in there, should I replace the knock sensor? It worked fine before I removed the engine. I just have no idea how long these things last.
Old Apr 4, 2022 | 04:50 PM
rla2005's Avatar
rla2005
No reason to replace it. May not be able to find one anyway.
Old Apr 5, 2022 | 07:14 AM
llama's Avatar
llama
Thanks for your input.
Old Apr 5, 2022 | 12:09 PM
wwhite's Avatar
wwhite
Why don't the 351w have the knock sensor, mine is a 1994 and it does not?
Old Apr 5, 2022 | 12:29 PM
llama's Avatar
llama
I don't know. I've never had a 5.8.
Old Apr 5, 2022 | 12:33 PM
rla2005's Avatar
rla2005
As far as I know the 5.8L and 7.5L engines never had a knock sensor. Only the 5L and 4.9L engines have them.
Old Apr 5, 2022 | 05:01 PM
wwhite's Avatar
wwhite
Correct.
But why?
Will there be any added benefit adding knock to 5.8L?
Old Apr 5, 2022 | 05:03 PM
SFaulken's Avatar
SFaulken
Originally Posted by wwhite
Correct.
But why?
I mean, no, not unless the ECM knows what to do with it.
Old Apr 5, 2022 | 05:08 PM
wwhite's Avatar
wwhite
My recent discovery of a 1995 6cylinder computer has the exact same hardware as my 1994 8cyl computer, but the 6cyl has the additional knock hardware present.
They are basically 2 bank batch fire systems, same hardware for controlling trans as well.
I plan on hooking up the knock sensor, but before I do, I would like to know why it wasn't there to begin with.
Old Apr 5, 2022 | 05:14 PM
SFaulken's Avatar
SFaulken
*That* I have no idea. You'd really have to ask a Ford Engineer. I can't imagine that the 5.8 and 7.5 are particularly less prone to knocking than the 4.9 or 5.0 under similar conditions.
Maybe they are, but especially for the 5.0 vs the 5.8 that really doesn't make much sense, the engines in a given OBS model year, once everything went EFI are negligible, aside from the obvious mechanical bits and the displacement difference.
rocket_6
May 10, 2006 04:20 PM
rocklayer
1983 - 2012 Ranger & B-Series
Jan 7, 2005 04:04 PM
Bob Ayers
3.0L V6
Jun 9, 2004 12:29 PM
