knock sensor
Old Jan 7, 2005 | 03:37 PM
rocklayer's Avatar
rocklayer
knock sensor
Is it possible to hook up to the knock sensor and run a wire into the cab of the truck with a light that would come on when the knock sensor was activated? Where is the knock sensor located on a 03 ranger with a 3.0 engine? If you could do this, you would know for sure if your truck was knocking even if you couldn't here it.
Old Jan 7, 2005 | 04:04 PM
Rockledge's Avatar
Rockledge
There is no knock sensor on the 3.0L "vulcan" engine.
What you are proposing is doable (on a vehicle so-equipped) if you use a fairly sophisticated scanner or tuner that can provide "real time" feedback from the various engine sensors.
