Once I have my new fuel pump all back together, do I have to bleed the air to prime the pump, if so how?? Should I fill the fuel bowl prior to turning the engine over?
All I did was fill the bowl & started the motor ...
Just make sure you don't have any dirt in the filter housing.
found out sun that I had got some junk in there, and that's what's been tripping my water in the fuel light.
I don't see an issue with it. There are oil passages to lubricate the injectors, the fuel has lubricating properties but is not needed to lube the injector...
