1978 - 1996 Big Bronco
Timing Issues
Old Apr 11, 2022 | 08:18 PM
WTDWN's Avatar
WTDWN
4wd Low
Thank you all for the help.
I would like to add, for the time being, I set the advance quite a bit further. I beleive my total advance is reached at 2800-2900 RPMs, and a reading of 48 deg total timing. Runs a lot better, but is really hard to start.
I can keep it here for the time being, but would like to know if anyone else is running that kind of advance.
Old Apr 11, 2022 | 08:23 PM
torq'ta 5 8's Avatar
torq'ta 5 8
This may help you -->Timing Curve - Ford Truck Enthusiasts Forums
Old Apr 11, 2022 | 08:43 PM
manicmechanic007's Avatar
manicmechanic007
38 total is normal
Maybe back it off just a hair and try that
Old Apr 11, 2022 | 08:47 PM
Kramercd's Avatar
Kramercd
I run 14* initial timing. 26* of mechanical advance. 24* of vacuum advance. I think the most timing I pull the way it's curved is 56* at 2500rpm. I have a dual vacuum signal input to the vacuum advance. I've only seen one other truck set up that way. I have Venturi vacuum and manifold vacuum teed together with a check valve that reduces the manifold signal something like 5". Makes the vacuum signal a bit smoother best I can tell from mapping it. Now, I spent a lot of time fiddling with mine and getting it where I wanted it. I want to say the standard is 36* total mechanical or 54* total timing, something in that range.
Old Apr 13, 2022 | 07:50 AM
WTDWN's Avatar
WTDWN
4wd Low
So question on that, and I will post it in the other thread as well, when I push the throttle, I loose ALL vac advance. and when I brought it up to 2900 RPMs. I had 48-52* Total. according to my dial back timing light. Should I be using a "T" and using man vac and carb vac?
Old Apr 13, 2022 | 07:57 AM
Kramercd's Avatar
Kramercd
I wouldn't. I'd just run ported vacuum. The signal is supposed to drop off under a heavy load. Shouldn't have anything at wide open throttle. All my readings I pulled in my thread were at cruise. The timing would be quite a bit different under acceleration.
Kramercd
42
Apr 3, 2022 07:48 PM
Go Seahawks!
338
Dec 12, 2021 07:47 PM
hivoltj
41
May 19, 2019 11:31 AM
justroll
Apr 28, 2019 06:33 PM
oldnumber9
13
Apr 13, 2016 11:27 PM
