Pan sump
Old Apr 1, 2022 | 11:39 PM
triorez25's Avatar
triorez25
Pan sump
I'm saving up to put in a crate 351w in my 84 f150 and I'm unsure if it needs to be front or rear sump
In the same vein which side should the inlet of my water pump be? Does it matter?
Old Apr 2, 2022 | 12:35 AM
Rusty_S's Avatar
Rusty_S
Trucks are all rear sump oil pans you wont be able to run a front sump on a truck.
As far as the water pump goes it should be a driverside inlet on the Ford trucks at least they are on the V-belt setups dont think the inlet hose changed on the serpentine belt but I am not too well versed on those accessory drive systems as I havent messed with them much.
Old Apr 2, 2022 | 01:00 AM
triorez25's Avatar
triorez25
Roger thanks
Old Apr 2, 2022 | 06:21 AM
Franklin2's Avatar
Franklin2
You will probably need to save and re-use your old oil pan, oil pump pickup, and main support stud for your new engine.
Old Apr 2, 2022 | 06:53 AM
FuzzFace2's Avatar
FuzzFace2
And if he is going from a 300 six than what?
Even the radiators are different between the 300 six and v8's
Dave ----
Old Apr 2, 2022 | 08:24 AM
kr98664's Avatar
kr98664
The instructions with my replacement engine (351W) said to replace the oil pump pickup tube instead of reusing it. It has a coarse screen that is not fully accessible for cleaning. Rockauto had them, around $30 IIRC.
For the oil pan, I would highly recommend upgrading to the one-piece rubber gasket instead of the original cork multi-piece leak generator system.
Here is some suggested reading about oil and break-in procedures, too. I've already got the T-shirt, but don't let this happen to you:
https://www.ford-trucks.com/forums/1...diagnosis.html
https://www.ford-trucks.com/forums/1...brication.html
Old Apr 2, 2022 | 02:55 PM
Rusty_S's Avatar
Rusty_S
For the pickup I used the Melling pickup for our trucks they still make it to go with my Melling M68A high pressure oil pump. The pan I got was a NOS pan I found on Ebay but it was the replacement number with some minor differences to the original pan I have on the engine that is still in my truck.
There are also aftermarket companies making steel stock replacement oil pans for our trucks I saw them quite a bit when trying to find a NOS Ford stamping.
Old Apr 2, 2022 | 07:41 PM
Franklin2's Avatar
Franklin2
On the oil pan thing, it's best to get one that has the dipstick going in the pan. Unless you know for sure, don't count on your engine block to have the dipstick in the rear of the block. I have heard some had a plug back there you can punch out and mount the dipstick in the rear of the block but I am not sure all older v8's had this.
lizardman1
Nov 25, 2024 10:55 AM
friskyspatula
Jun 25, 2010 01:26 PM
82f1504x4
Jan 5, 2005 04:14 PM
shazam
Jul 23, 2002 12:31 PM
