360 Tear down
Old Apr 1, 2022 | 07:46 AM
Dans72's Avatar
Dans72
360 Tear down
The weather warmed up and I was able to get back to work on the '72. I pulled the engine (196,000+ miles), tore it down only to find the old girl was into the copper on all the bearings. Now it's completely gutted with one exception, the camshaft will not by any stretch of the imagination move past the second bearing set! Everything is out, no lifters in the way and it totally binds up, even using assembly lube on the cam bearings. It's going to the machine shop today, so I'll let them get it out, but has anyone ever had this problem?
I was also looking at all the parts during disassembly, all of which are standard 360 parts from Ford with the exception of #1 piston. That piston was clearly marked 390 4V in the pin pockets. 2- 8 are all 360 pistons.
Can't wait for this heart transplant to be finished and get "Forest Bump" on the road again!
Old Apr 1, 2022 | 11:07 AM
f5fordgirl's Avatar
f5fordgirl
Never know what you'll find in a 50 year old engine, tore down a 330 FH that had a reman tag on it, one bank had D shaped piston tops, other bank had round, and 5 of the rods were marked #5.
Old Apr 1, 2022 | 05:06 PM
Dans72's Avatar
Dans72
Absolutely true! I've seen some real fly by night or shade tree repair jobs in my day!
Old Apr 1, 2022 | 05:14 PM
85e150's Avatar
85e150
One piston is marked "390 4V". That should be a flat top with valve reliefs.
What do the other pistons look like?
The 360 piston IS a 390 car piston. 390 2V pistons have a slight dish and the valve reliefs. IIRC both types have been found by members here. Not sure about finding both types in the same engine but as we see in post 2 stuff like that happens.
Old Apr 2, 2022 | 07:18 PM
Dans72's Avatar
Dans72
Finally able to remove the camshaft. The front bearing was really messed up and I'm surprised it didn't seize before hand! Really glad the block is headed to the shop!
Old Apr 3, 2022 | 11:15 PM
nortega69's Avatar
nortega69
For future reference. I took the timing sprocket bolt and cut a piece of wood to length. I then fastened the piece of wood to the cam. It resembled a propeller lol. I was then able to work it back and forth while pulling it out. It worked for me. I would assume in your case it may or may not have worked because of the messed up bearing but it worked for me.
Old Apr 6, 2022 | 01:32 PM
Greaser007's Avatar
Greaser007
I have to chuckle when guys rebuilding an engine are concerned about 1/2 thousandth (.0005"), but when we tear down used engines we may find mismatched pieces and parts running with five or more thousandths (.005") bearing clearances, and the engines were galloping down the highway before tear-down.
wyandotteman
Mar 12, 2022 10:19 PM
NZDDS
15
Nov 11, 2019 08:08 AM
Vash_71
Dec 8, 2007 03:54 PM
Jsbiohazard
Mar 13, 2003 06:23 AM
robertskunfused
Dec 14, 2002 07:37 PM
