For lack of a better description.
2006 E250 cargo.
The bellows between the body and doors are suffering, and I would like to replace them while I am running some wires.
Passenger side barn doors first.
Wife has requested table and some lighting for the "rolling tool shed"
I would love to find the part numbers, and proper name!
Was discussing this earlier with a guy, talking about using a spring, that is what Ford used in the rear door of my 73 for the license plate wiring, or a gas line could be inserted to run wire through.
The "bellows" found on the '06 E-Series are a bit more complex in how the existing wiring is run through them. The wiring Ford runs through them is physically attached to the part itself---when I've modified the existing wiring I've disassembled the entire chassis wiring harness from the part.
To replace one of those you'll have to remove the existing wiring and factory connectors as a complete sub-assembly. I've almost never seen any of those in unacceptable condition unless someone has caused damage in some way.
