4R100 stalls engine when put in reverse while cold
Fresh rebuild with lots of new parts including billet triple-disc torque converter.
It has a new 6.0 transmission cooler and no radiator trans cooler (L99). Filled with Merc V fluid that still looks new.
No issues at all after warm. Shifts good and TCLU is perfect. Does have PHP tunes on Hydra chip.
Transmission shop is suggesting synthetic ATF based on TSB’s they found for this issue - but I’ve never had this problem before????
Suggestions??
It's a low pressure issue, either from internal leakage (the initial shift from anything into reverse is oil hungry inone of these), or a torque converter issue.
Correct filter?
Like Cody said, I’ve read Mark say many times about TC going into lockup if fluid is low.
