Front end questions
Old Mar 31, 2022 | 08:40 AM
Slyfox1984's Avatar
Slyfox1984
Front end questions
Good morning, can anyone tell me a good front end to put on a 49 F1 that is going to house a 24V 5.9. I am trying to make it 4wd also with an allison behind the engine.
Old Mar 31, 2022 | 09:03 AM
EBEAR's Avatar
EBEAR
Welcome . If you are going to make it 4x4 you will definitely be limited . Width would be first as any full size would be far too wide so you will need to use a small to midsize front , next would be straight axle or independent . A straight axle would be the easiest but would need to be able to match gear ratios of your rear diff and have a compatable front drive layout . I believe the only trucks - info you are going to find will be from complete frame swaps . As with anything this complicated you will need ALLOT of measuring . Good luck .
Old Mar 31, 2022 | 10:14 AM
48 Steel's Avatar
48 Steel
Check this out- https://bringatrailer.com/listing/19...-f-1-pickup-8/
Old Mar 31, 2022 | 11:50 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Originally Posted by 48 Steel
Nice looking truck. The body is a little rough, but it presents well.
Mike Morrison
Jan 12, 2016 06:50 AM
tmsmart
Sep 16, 2009 09:54 AM
OffRoadF-150
Offroad & 4x4
Jan 17, 2006 05:33 PM
phonebooth
Jun 22, 2005 05:37 AM
Marlboro L
Apr 3, 2005 11:57 AM
