Offroad & 4x4
Mounting the Axle
Old Jan 16, 2006 | 05:16 PM
OffRoadF-150's Avatar
OffRoadF-150
Mounting the Axle
Im ready to mount my D44 for the SAS. What steps should i take to make sure the axle is mounted perfectly? I havent figured out the exact placement on the new radius arm brackets. Any advice will help.
96 f-150 w/ 78 front end
Thanks,
Will
Old Jan 16, 2006 | 08:39 PM
surewhynot's Avatar
surewhynot
I am in the process of doing the same thing. the way I did it was measuring from the rear end to the front on each side to make sure it was even. Just be patient and check everything twice. Then re check everything twice. I don't know if it's important or not but I had jackstands holding my frame up at the height the truck will be while I made my measurements. Heres the thread about my project- https://www.ford-trucks.com/forums/s...d.php?t=449070
If you have any other questions or if I can explain any better feel free to pm me. I hope to have more pics up tomorrow. I have the front done now except for a few odds n ends.
Tony
Old Jan 17, 2006 | 05:33 PM
chrono4's Avatar
chrono4
find a common point, the same distance from end on each side, like the rear axle. meaure up, and mark, measure, tack, measure measure measure, weld. get a good alignment afterwards.
86 f250 4.9l
Jun 4, 2016 07:45 AM
jereli
Apr 6, 2016 03:24 PM
olrebelford28
Dec 23, 2015 01:21 AM
adamax21
2004 - 2008 F150
Apr 24, 2011 11:16 AM
roofcam
Aug 14, 2009 01:05 AM
