drivetrain transplant
Old Mar 27, 2022 | 11:03 AM
egchewy's Avatar
egchewy
posted this in my "rebuild" thread, but I'm thinking of replacing my tired motor/trans.
Another member recommended going to a 460/C6 pairing.
are other SBFs an option? will they fit the frame mounting points without mods?
I'd love to hear suggestions. Not looking to tow anything but would be nice to have that option down the road.
Budget of course is always a consideration. I've seen some reman'd 460s for under $3k and C6s for around $2k.
Any engine builders or reman'd shops to consider?
Old Mar 27, 2022 | 12:27 PM
Deerhunter4's Avatar
Deerhunter4
I’m not sure where you are located or the truck you are working on but I have a big block C6 (it’s a 4wd trans) in the shop just taking up space if you want it. I’m located near Amarillo, Texas.
I bought it from a local a couple of years ago but never installed it so I don’t know the condition but all parts are with it including a torque converter.
I ended up going with a ZF5 mainly for the overdrive and granny 1st gear. I ran a C6 for a while but the high rpms on the highway were bothering me. You might want to consider an overdrive trans if you do a lot of highway driving. There are several options if you want an auto. A good 460 takes huge advantage of overdrive.
Old Mar 27, 2022 | 12:51 PM
FuzzFace2's Avatar
FuzzFace2
It may help if we knew what the truck is , year / model / 2wd or 4wd, and what it has now for motor & trans.
You said SBF but the 460 is a BBF and would need a trans to match the bell bolt pattern.
Dave ----
Old Mar 27, 2022 | 03:37 PM
egchewy's Avatar
egchewy
it's a 1979 F150 4x4. I believe the drivetrain is factory, but not completely sure.
I'm new to the truck game and havent' been able to identify the motor/trans combo yet.
I'm on spring break this week but can take some pics.
Where are the casting codes?
Old Mar 27, 2022 | 07:32 PM
arnegrant's Avatar
arnegrant
What are you using the truck for?
Mileage, I would go 302 (a small v8)
Longevity, with low maintenance - hard to beat a 300 straight 6
460s will pass anything but a gas station. Not sure you need that much go in a half ton
Coolest is the 429, hard on back tires though ; )
351W is a nice betweener.
If you can get a good deal on a 400 they go too
I would look for something with a good deal, and then rebuilding your own is always the surest shot (you know what you got if you do it or have it done yourself)
Good luck
Old Mar 27, 2022 | 10:43 PM
egchewy's Avatar
egchewy
weekend cruiser is the plan currently. trying to price out drivetrain swap vs rebuild of what I've got.
it's real easy for these budgets to balloon out of control.
Old Mar 27, 2022 | 11:15 PM
ivsamhain's Avatar
ivsamhain
If it’s factory it’s a 351m or 400. It bolts right back in and that’s worth a bit of work between mounts and exhaust and what bolts to your trans(bbf)-transfer case-drive lines.
Old Mar 28, 2022 | 09:57 AM
tbear853's Avatar
tbear853
You could count the valve cover bolts to quickly narrow down what it is that you have in it now.
2 bolts: "Y" Blocks
239/256/272/292/312 (produced from 1954 to 1964)
5 bolts: FE Series
332/352/360/361/390/391/406/410/427/428
6 bolts: SBF group
221/260/289/302/351W
7 bolts: 385 Series
429/460
8 bolts: 335 Series
351C/351M/400
Like already said, most likely a 351M, maybe a 400 but could be something else, it is 40-odd years aged after all.
351 has 3-1/2" stroke, 400 has a 4" stroke.
Typically, my 351M gets a reliable 11-12 mpg, but I did once on a vacation carry extra jets and 2 power valves for my then Holley, tried a few either side of Holley "out the box" setup, varied timing, managed 16 mpg on one setup, on one leg from Dover DE to Cumberland MD ... but it burnt a couple valves shortly afterwards so I reverted to safe setup and less mpg when I R&R-ed the heads, lesson learned.
Old Mar 28, 2022 | 10:25 AM
ivsamhain's Avatar
ivsamhain
If it hasn’t been swapped, fourth letter of vin s=400 h=351
my tired ol 400 gets 8mpg 78 4x4
Old Mar 29, 2022 | 12:22 PM
egchewy's Avatar
egchewy
found a 460/C6 for sale on FB marketplace for $900.
deal or no deal?
Old Mar 29, 2022 | 02:05 PM
ivsamhain's Avatar
ivsamhain
If you have an auto in there just have to deal with motor mounts and exhaust.
Old Mar 29, 2022 | 02:18 PM
fordrealdrive's Avatar
fordrealdrive
Deleted...
Old Mar 29, 2022 | 02:32 PM
ivsamhain's Avatar
ivsamhain
Save a lot of headache using the trans in the truck.
Old Mar 29, 2022 | 02:34 PM
egchewy's Avatar
egchewy
Dunno. I’ll ask. But $900 for a “running” 460 seems like a good deal, if nothing else for the block, unless it’s cracked. Aren’t they all “ running when pulled” though?😂
Old Mar 29, 2022 | 02:56 PM
ivsamhain's Avatar
ivsamhain
it’s not terrible. Depending what it’s out of it might not be real impressive without dropping a bit of coin. I picked up a 460/c6 with radiator and accessories recently for $400.
