1985 Vent window frame
Old Mar 26, 2022 | 06:24 PM
RH15311's Avatar
RH15311
Gentlemen,
I have an 85’ F250 6.9 diesel that I’m beginning to restore. Can anyone recommend where I can find them? I’ve been searching online but without any luck. I would like new frames but I may have to go to my local Pick & Pull.
RH
Old Mar 26, 2022 | 07:46 PM
85e150's Avatar
85e150
Welcome to FTE.
Moved to the forum for your truck.
Looks like you can get them here:
https://www.dennis-carpenter.com/pro...t+window+frame
Old Mar 27, 2022 | 11:51 AM
FuzzFace2's Avatar
FuzzFace2
If you do the PnP route just watch the as the window dividers are different between the later years.
Before you go hunting measure your divider how wide they are and the ones in the PnP.
Now I dont know / remember if you can fit the wider ones in the door or not, dont think you can as that is how I found out they were different.
If you can fit it in the door then you also have to use the door glass that goes with the divider as it would be a different size to match the divider.
IIRC the wider dividers are also longer and why I could not get them in the doors.
Thin divider on top of the wide one
I think the vent glass & frames are the same between the dividers so they should interchange as I think thats what I had to do once I got good dividers to make a complete set for my doors.
I say think as it has been many years since I played with this.
Dave ----
hooler1
Apr 24, 2021 06:39 PM
calvin42
Nov 11, 2008 01:56 AM
65f100pdx
Aug 1, 2008 11:58 PM
77' f-100 ranger xlt
Jan 24, 2006 03:39 PM
