53 F100 start button
Old Mar 25, 2022 | 04:47 PM
Pappys53's Avatar
Pappys53
I have rewired my 53 using stock ignition with start button. I have a neutral switch wired in. But without ignition key on, there is still power to the start button and will try to start the engine. I thought I tested that after installing my floor shifter and hooking the neutral switch up and there was no power to the button. What could have changed or do I have something hooked up wrong?
Old Mar 26, 2022 | 07:40 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Your power wire to the solenoid should go thru the start button, to the neutral safety switch then from the neutral safety switch to the ignition switch.
Old Mar 26, 2022 | 08:19 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
It sounds like it is on the "AM" side of the switch, not the "RAD/GA" side of the switch.
"AM" = (Ammeter) Incoming power source
"COIL" = Switched power to ignition system
"RAD/GA" = (Radio/Gauges) Switched power to everything else
Pappys53
Aug 13, 2015 09:16 PM
chrisginco
22
May 14, 2013 12:17 AM
Ricky St. John
Jan 13, 2013 01:21 AM
vinny80
May 10, 2011 02:10 PM
f1fordguy
May 31, 2006 08:18 AM
