Start Button-48 F1
Old May 30, 2006 | 02:02 PM
f1fordguy's Avatar
f1fordguy
Start Button-48 F1
Any reason i can't use my push start button with a modern keyed ignition? Seems like it would be fairly easy to wire up. Surely the push button could handle 12 volts!
Am I missing something here?
Old May 30, 2006 | 02:27 PM
Randy Jack's Avatar
Randy Jack
Tim -
You are correct. No problem. The 6V button will only carry half the amps at 12V. I have a GM column (with a key) and use a start button anyway.
Old May 30, 2006 | 05:08 PM
4tl8ford's Avatar
4tl8ford
When I got my truck the ignition had the key broken off and the normal hot wires to twist togeather, then hit the button.
I grabbed a modern style switch and put it in for convience.
It was fun to watch people try to figure out how to start the truck, especially when I would make a big deal around the key while slipping the other hand over to the Button.
Old May 30, 2006 | 08:39 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I'm using my original start button with a column mounted ignition switch, however, I'm not using it for a start button. I mounted it on the floor and wired it to a line lock solenoid for the brakes......
.....I couldn't resist, I had one years back in a drag car and thought it was alot of fun.
It should be easy to wire up do a news style ignition switch, go for it
Bobby
Old May 31, 2006 | 07:54 AM
GreatNorthWoods's Avatar
GreatNorthWoods
It makes a good horn button. That's what I'm using mine for...
Vern
Old May 31, 2006 | 08:18 AM
51ford fan's Avatar
51ford fan
Vern
Great idea thanks !!!
Rod 51F1
bourcier1990
13
Aug 31, 2011 08:55 PM
JaysRanger
Electrical Systems/Wiring
Aug 19, 2007 10:04 PM
tip49
May 27, 2007 12:44 PM
beaners1
Feb 13, 2007 08:53 PM
mitchw32
Jan 31, 2005 08:21 PM
