Gross Combined Weight rating differences
Old Mar 22, 2022 | 08:25 PM
Dustin F450's Avatar
Dustin F450
Looking at the 2021/22 F450 crew cab and regular cab, WHY does the crew cab have a lower GCWR of 43,500 lbs vs the regular cab GCWR of 45,300lbs? I figured it would be the same but the regular cab have a higher tow rating because of the lighter curb weight.
The 250The350srw, and 350drw all have the same GCWR regardless of cab.
why is the F450 pickup different?
Dustin
Old Mar 23, 2022 | 05:24 AM
senix's Avatar
senix
probably because of the curb weight of the crew cab.
Old Mar 23, 2022 | 07:15 AM
Dustin F450
The crew cab is only 400lbs heavier. How does the weight of the crew cab affect the GCWR? It should have the same GCWR regardless of cab configuration. That's how the 250 and 350s are. Are they worried about thr frame bending behind the cab? The 450 is the only truck that has a difference in GCWR with only a cab change...and nothing else...GCWR usually changes with gearing IE 4.10s 40,000lbs, 3.55s 36,000lbs, not cab.
Old Mar 23, 2022 | 07:26 AM
senix's Avatar
senix
I agree. I will have to look into this myself too. An interesting observation.
Old Mar 23, 2022 | 07:58 AM
Dustin F450
If you find something out, let me know, I'm curious. Thank you
Old Mar 23, 2022 | 11:20 AM
Dustin F450
I'm thinking it's a mistake. They should be reversed. The reason is the crew cab with its longer wheel base will be more stable towing even GN/5th wheel. Everything is the same except for the cab configuration. Tires, gears, engine, trans, axles brakes and cooling system. Why is the crew cab rated 1800lbs lower than the regular cab?
Hopefully Senix gets some good information...
Old Mar 23, 2022 | 02:26 PM
chadstickpoindexter's Avatar
chadstickpoindexter
There are misprints in the towing guides and even the owner manuals. When getting my F250, I was baffled because the towing guide showed that my truck with lesser rated AS tires had a higher towing capacity than the same size AT tires, but with higher ratings. Made no sense... I can't answer your question, but misprints wouldn't be unheard of...
Old Mar 23, 2022 | 03:48 PM
Sport45's Avatar
Sport45
I agree. Could be as simple as someone miss-typing the 3 before the 4 on a spreadsheet. (Or the 4 before the 3,..)
Old Mar 26, 2022 | 08:18 AM
Desert Don's Avatar
Desert Don
When they “rate” pickups, there are timed pulls, both forward and reverse, starting and stopping. These have nothing to do with the stregth of materials and components. That is why a truck with deeper gears will be rated to pull more that a truck with tall gearing. And this is all just to meet a “standardized” test so that all manufacturers that have agreed to rate their trucks by the same test.
https://www.motortrend.com/how-to/15...-the-standard/
https://jalopnik.com/what-is-sae-j28...cks-1593305929
Maybe this will help clarify things a bit.
eli98
Apr 29, 2018 04:20 PM
tilopa
Sep 3, 2015 06:11 AM
johndeerefarmer
2009 - 2014 F150
Sep 5, 2010 07:48 AM
hickorycornerfarm
Apr 7, 2007 12:18 AM
