Abs hydraulic unit replacement
Old 03-22-2022, 08:16 PM
bigredtruck's Avatar
bigredtruck
bigredtruck is offline
I have a 2000 3.0 2WD and my ABS hydraulic unit is leaking. Everywhere I look, this part isn’t available for any year past 1997. Anything 1998 and up just shows an entire ABS control module. Will a ‘97 part fit my truck?
Old 03-24-2022, 11:06 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
Seeing as how this is a safety issue & could become a Big legal issue in case of an accident involving a braking problem, non-conforming or specified parts could become a serious issue in more ways than one, so best if we use the specified parts, that can be looked up for your factory build, by entering the vehicle VIN # here. Parts.Ford.com | The Ford Parts Site | Buy OEM Ford Parts Online‎
Old 03-24-2022, 08:27 PM
bigredtruck
It looks like I need this, but everywhere says its discontinued.
Ford XL5Z-2B373-AARM
Modulator Valve Assembly1998-2000 Ford Ranger XL5Z2B373AARM
Old 03-25-2022, 01:09 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
Maybe try calling your trusted local salvage yard & see if they have one, or can source one though their network.
Old 03-25-2022, 10:12 AM
Kruse's Avatar
Kruse
Kruse is offline
Looking at the limited parts books that I have, it appears this part fits only '98and up vehicles, so a part from a '97 won't work. And, like you've noticed, all original sources for this part have had it discontinued and is NLA. Ford seems to be famous for stuff like that.
Ironically, I have a '98 Ranger 2WD 3.0 which will be parted out this year, but I'm currently driving it, so I can't help you there. (BTW, I popped the hood on my vehicle this morning to make sure they are the same and they appear to be)
Your best choice, as previously stated, is to hit the salvage yards and see if you can't find one there. I'd bet somebody local has one. I also agree that substituting a part from a previous year could open yourself up to a legal can of worms even if it did work. But that's just me.
ALL THAT BEING SAID, looking at your photo, it appears that it is leaking on the bottom where there is a nut and probably an O-ring and the fluid is blowing back as you drive down the road. (For people viewing and not knowing, the right side of the photo faces the front of the vehicle and the left side of the photo faces the rear of the vehicle with this ABS modulator sitting on top of the driver's side wheel well under the hood) As a last resort, could you remove this modulator and hold it in a shop vise and see of the nut can be tightened? I'm thinking that a good tightening with a closed-end wrench might just stop the leak. Or, it might make it worse. Anyway, I would think it would be worth a try. Good luck.
norman15
Large Truck
05-14-2021 02:51 PM
xmontex4
1999 to 2016 Super Duty
07-22-2016 06:28 AM
89MustangGX
06-10-2004 12:03 AM
95fordbronco302
1978 - 1996 Big Bronco
03-06-2002 04:29 PM
Quick Reply: Abs hydraulic unit replacement
