Thanks for your response!
I installed a fuel pressure regulator today and dialed it down to 4 1/2. I also checked the little screen right inside the fuel inlet on carb (looks clean). I will road test it tomorrow morning to see if lowering psi works.
This is what has been done last month:
I just replaced everything fuel related, including new fuel tank. 2 new filters, fuel lines, etc. Carb is brand new, purchased last month.
Distributor= MSD Flamethrower 2 (new), MSD Blaster 2 Ignition Coil (older), no box.
Flowmaster exhaust with nice headers (not sure on brand for headers).
Timing= set mark at 0 tdc, (tdc is correct/hand cranked engine until #1 was at top) used timing light to set to around 8/9 initial. Did not set total timing yet. Idle speed is 600 rpm.
Adjusted fuel/air screws on carb with vacuum gauge and is steady.
It seems that the bogging started after I installed new carb. The old carb (1404 edelbrock) was pushing fuel through vacuum advance line into distributor diaphragm and It caused my truck to die.
Just wondering, when you put in a new fuel tank did you use your old gas cap or replace it it with a new one. If it's new you might try using your old cap and see if it helps. Some of the replacement gas caps are not vented and can draw a vacuum in your fuel system and cause a problem.
Good call but I would try with no cap this way you know the tank is vented.
Dave ----
