Bogging Down Issues
Old Mar 22, 2022 | 10:22 AM
wtx66f100's Avatar
wtx66f100
Originally Posted by Fordf1006578
Thanks for your response!
I installed a fuel pressure regulator today and dialed it down to 4 1/2. I also checked the little screen right inside the fuel inlet on carb (looks clean). I will road test it tomorrow morning to see if lowering psi works.
This is what has been done last month:
I just replaced everything fuel related, including new fuel tank. 2 new filters, fuel lines, etc. Carb is brand new, purchased last month.
Distributor= MSD Flamethrower 2 (new), MSD Blaster 2 Ignition Coil (older), no box.
Flowmaster exhaust with nice headers (not sure on brand for headers).
Timing= set mark at 0 tdc, (tdc is correct/hand cranked engine until #1 was at top) used timing light to set to around 8/9 initial. Did not set total timing yet. Idle speed is 600 rpm.
Adjusted fuel/air screws on carb with vacuum gauge and is steady.
It seems that the bogging started after I installed new carb. The old carb (1404 edelbrock) was pushing fuel through vacuum advance line into distributor diaphragm and It caused my truck to die.
Just wondering, when you put in a new fuel tank did you use your old gas cap or replace it it with a new one. If it's new you might try using your old cap and see if it helps. Some of the replacement gas caps are not vented and can draw a vacuum in your fuel system and cause a problem.
Old Mar 22, 2022 | 08:03 PM
FuzzFace2's Avatar
FuzzFace2
Good call but I would try with no cap this way you know the tank is vented.
Dave ----
Old Mar 29, 2022 | 06:03 PM
wtx66f100's Avatar
wtx66f100
Any updates on your bogging down problem?
Old Apr 1, 2022 | 09:46 AM
Fordf1006578's Avatar
Fordf1006578
I didn't have a chance to buy a tester, but I did put my old regulator on, and took it down to 4 psi. It still bogs down.
Old Apr 1, 2022 | 01:52 PM
Red60's Avatar
Red60
I am wondering if its an over time thing (as in bogs at speed vs also when running hard in low gears)? Can you get it to happen on cue?
Old Apr 1, 2022 | 02:18 PM
Fordf1006578
No. It happens at cruising speed and is completely random. It didn't happen at all today.
Old Apr 1, 2022 | 05:49 PM
Red60's Avatar
Red60
Shooting from the hip sounds electrical such as key or such...
Scott M-47
Aug 1, 2020 10:34 PM
rews2
Mar 1, 2016 05:25 PM
tyrantsparky
Arizona Chapter
Apr 25, 2013 08:40 AM
Big73
38
Jul 18, 2011 08:50 AM
sauerf100s
Mar 9, 2002 11:24 AM
