9 inch help
Old Mar 18, 2022 | 06:19 PM
maverick600's Avatar
maverick600
9 inch help
79 F100
Donor rearend
I'm curious if the bearings are the same for the axles or will I have to change the housing also.
Old Mar 18, 2022 | 07:46 PM
85e150's Avatar
85e150
WDM-CJ Ford F100, F150 Pickup '79 2.75 9 in NL 28 - Ford F100, F150 Pickup '80-'82 2.75 9 in NL 31
S319D Bronco 85-89
Ford F100 Pickup, F150 Pickup '85-89 3.50 9.0 L 31
You should plan on new bearings and I think you have to get them pressed on to the axles, so you'll be able to see all the sizes involved. You are changing from 28 to 31 spline so at least the ID of the bearing would be different--I think--.
Source:
http://www.fordification.com/tech/rearends_ford11.htm
Old Mar 18, 2022 | 07:49 PM
maverick600
S319D Bronco 85-89
Source:
Ford Rear Axle Assembly Identification - Page 11 - FORDification.com
I appreciate the answer. Yes, they will have to be taken to a shop to get the bearings and seals swapped out. I'm just hoping I don't ha e to change the housing as well.
Old Mar 18, 2022 | 11:07 PM
85e150's Avatar
85e150
Said to be same width at 65 or 65.25 inches, with equal length axles and large bearings.
Ford F-150 9-Inch Axles:
The Ford 9-inch can be found under 1974-1986 F-150s and 1978-1986 Broncos. It features the legendary Ford 9-inch ring and pinion strength, 5-on-5.5 lug pattern (same as older Jeep), a 65-inch width at the wheel mounting surfaces, large-bearing semi-floating axles, and many can be found with hefty 31-spline axleshafts. Another bonus is that the axleshafts are of equal length, so you’ll only need to carry one spare should you choose to.
Source:
https://www.therangerstation.com/tec...nchAxles.shtml
Old Mar 18, 2022 | 11:11 PM
85e150's Avatar
85e150
Before you lay a wrench anywhere, consider looking at the entire S319D axle, housing and brakes. It it has larger brakes and is a direct bolt in, I'd go for that.
Swerving suggestion.
Old Mar 18, 2022 | 11:14 PM
maverick600
Source:
So, it was suggested that the 2 may have different types of bearings. My 79 has a rear axle bearing like the front wheel bearings. Is it possible that the donor would have a sealed bearing and if so, would either work in my housing?
I'll be able to answer this question tomorrow when I go to the storage unit. Didnt know if the difference between the 28 and 31 spline axles made a difference in bearing outer diameter.
Old Mar 18, 2022 | 11:16 PM
maverick600
I am considering this option but the entire housing will need work. Brake lines, vent lines, brakes, etc. I guess I should have known it wasn't going to be as easy as anticipated.
Old Mar 18, 2022 | 11:24 PM
85e150's Avatar
85e150
DNK about the bearings. Tapered roller and ball are the only ones I've seen.
Old Mar 19, 2022 | 02:52 PM
maverick600
So after going to storage, the bearings are the same type so I am having someone change the bearings and seals.
I pulled the chunk on my 79 today and wanted to post the numbers off the ring gear.
DLAW - 4210A 10-4-78 16x44 M I P A
isenegger
Oct 25, 2024 01:34 PM
66ordie
217
Feb 16, 2020 08:45 PM
hav24wheel
Offroad & 4x4
Aug 18, 2011 07:46 AM
my69
13
Jul 23, 2011 12:28 PM
FuelishPleasure
Nov 9, 2010 10:48 AM
