I'm curious what adjuster screws do what on this 1984 351w 2 barrel cab I've found the choke and idle ajust I'm not sure what the other two do
The red points out the ones I've figured out which are the choke and the idle the blue are ones I'm not sure about any clues?
Well, by way of getting you back to the top of the page for others to see, my limited knowledge says that the one on the right looks like the transmission kickdown lever adjuster and the one on the left looks like the choke's high-idle adjuster.
Don't take that as gospel, but wanted to put my 2cents worth out there for debate.
Paul
I believe you are correct. The blue all the way to the left may be the choke pull-off adjuster. Not sure about that either.
