2100 Carb Issues
Old Feb 17, 2011 | 01:08 AM
DrunkFord's Avatar
DrunkFord
2100 Carb Issues
1981 F150 w/ 302 and a 2100 carb 1.08 Venturi and automatic choke.
Not sure if important:
Had the 1.02 venture (electric choke) in when I bought truck last year. Resently bought and rebuilt a 1.08 and threw it in the truck.
The air/fuel ratio is fine, but the choke sounds like it runs at probably 3000 to 4000 rpms when in park and drops down to normal when in gear. So its currently tough to set the idle adjustment because if its too low the truck will stall when driving. I tried the adj screw on the choke, but that made absolutely no difference. Is there an adjustment I am missing? Or do I need to open the choke assembly?
Any help or reference pages would be greatly appreciated
Old Feb 17, 2011 | 11:25 AM
Franklin2's Avatar
Franklin2
You need to warm the engine up and set the choke to off before setting the idle speed.
Old Feb 18, 2011 | 01:02 AM
DrunkFord's Avatar
DrunkFord
Awesome, thank you very much! I'll do that tomorrow
jwatson1969
Jun 8, 2013 09:22 AM
Shrevmo
Jun 17, 2009 06:58 AM
1954F250
Sep 4, 2008 11:11 AM
cjben
Apr 14, 2003 11:45 AM
