We're considering an order for a Powerboost, but one thing that is troubling (to me) is how the gas engine gets no time to warm up before being called into use...
Anyone else see this as a problem? Or, is it a problem?
I warm up, especially turbo'd motors, before ever asking for full power, but the Powerboost can often have the 3.5 EB in off mode...
Or maybe we just keep the truck we have - color is no longer available is one reason...
They are ways to make the motor start such as using the a/c, heater or even switching on the generator. For morning cold starts, by the time I pull out of my garage and wait for the door to close behind me, the engine is already running. I just sit there and wait about 2 minutes. Enough time for the oil to circulate. I also leave it in drive to keep the transmission pump going just for grins. After that, i just go easy for about 2-3 miles and then drive as normal. I do the same thing with my 450 diesel. The engine will generate more heat and reach optimal operating temps quicker with a load which is better overall. AND I am by no means **** about it, sometimes I forget and just go after my garage door closes.
I don't see it as an issue in the sense that Ford engineers have obviously taken this into consideration.
Hybrid vehicles have been out for a long time, so there is info out there for Ford to consider when designing the operation of the battery vs cold engine.
I'm not worried about it at all...zero amount of concern to me....and I'm strongly considering the powerboost model for my next truck.
In truly cold weather, the engine will start up immediately based on a few parameters. In moderate outdoor temps, it may or may not start right away, but it will within the first couple minutes of normal driving, and if you feel like taking it easy for another few minutes, that's not going to hurt anything.
Really, of all the things to like and dislike about the PowerBoost drivetrain, I think this should be pretty low on the list.
Warmup hasn't been a technical requirement for engines since EFI first appeared sometime in the mid '80's, as soon as there is sufficient oil pressure a motor is good to go.
OP, why don’t you want to drive it more? Superduty life is good!!!
on edit
I picked up a Maverick a couple years ago to keep miles off my Superduty. I put about 150k on a couple different ones, ultimately though I figured no sense in keeping it a garage queen, I bought it to drive that’s what I’m gonna do.
I'll repeat that in proper cold tems, the gas engine will start up even if the battery has enough power to "drive away" in pure EV mode. The gas engine does warm up automatically based on multiple sensors. That part of hybrid operation is handled really well by the computer.
Trust me when I say this, cold weather is not an issue in these trucks. There's many pros and cons to the hybrid system but cold weather is a total non-issue in the F150 (same as most hybrid vehciles).
