No compression #5
Old Mar 16, 2022 | 05:48 PM
Ralph Killington's Avatar
Ralph Killington
8th Gear
No compression #5
I have a 1999 f-550 has 225,000 miles and it had been running rough I decided to just start at the bottom and work my way up as to why, so I checked compression. so far I have only checked the passenger side and all have around 330-340 except 5 which only registered 100 checked four times made sure my tool was tight same results. My question is where do I go from here? What could be causing this? I bought the truck to fix and sell hoping for a profit but this may be a flop. Any help is appreciated and thanks in advance.
Old Mar 16, 2022 | 08:17 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
When it's running, do you have a lot of crankcase pressure escaping from the oil fill cap in time with the miss?
If so, it's replacement engine or rebuild time.
If the crankcase pressure isn't happening, then it's time to do a leakage test with pressurized air. It could be a bad seat or valve or even a bent pushrod or broken rocker arm.
Old Mar 17, 2022 | 07:25 AM
Ralph Killington
8th Gear
Could I get some instructions on how to perform the air test I’m assuming it’s just a leak down test. I haven’t checked for blowby at the cap and I’ve already got the valve cover off but a leak down test would reveal ring issues as well. Could an injector or cup cause low compression or just ring and valve issues.
Milasevich
Jan 23, 2022 11:01 AM
benbuilder
Aug 17, 2019 07:08 PM
gysgtbigdaddy
May 28, 2013 02:03 PM
showbizfcb
1983 - 2012 Ranger & B-Series
Jun 5, 2007 05:53 PM
