Sponsored by: Real Truck
Front suspension help!
Old Mar 15, 2022 | 05:20 PM
Boaterguy's Avatar
Boaterguy
2015 F250 CC 4X4 PSD, 88K miles
When it rains, it pours I guess. Just finished 1 repair, and another problem surfaces.
Pulled up to a stop sign and before we stopped moving, a large bang was heard in the area of the front left wheel. It was loud enough that the wife and I looked at each other like, "what the hell was that?" Didn't see anything out of place so we kept going. Truck seems to drive ok, but, while I don't hear any more noises, the front end has the feeling that something is loose when on uneven pavement or gravel roads. I can feel it in the steering wheel, and sometimes under my feet.
I used jack stands to get the weight off the front end and I cannot find anything out of place. No broken shocks, springs, or steering damper. I used a pry bar and have no movement in the track bar bushings. However, the large drag link bar that connects the 2 wheels together for steering has a rattle to it. Usually, if I twist the bar around, there is enough resistance in the ball joints to where it will stay in the whatever position i leave it in. Now, it rocks back and fourth with no resistance.
Now I am sure I am looking at a bar/ball joint replacement, but, I am really wondering what the initial loud bang was. It sounded like someone hit the underside of the truck with a hammer. Hopefully you all have some ideas before it gets to the shop. There is nothing worse than your truck sitting down there for 3 days and hearing "we are unable to duplicate the problem."
Old Mar 16, 2022 | 09:10 AM
bajaphile's Avatar
bajaphile
First thought in my mind would be sway bar related. Check the frame mounted bolts.
Rotation of the drag link and/or tie rod is normal about the ball joints, as long as there is no lateral play you're fine.
Old Mar 16, 2022 | 11:32 AM
Mike1's Avatar
Mike1
Check the U-Joints and knuckles on your front wheels Hub assemblies, Make sure one didn't seize and snap. Have you tried locking into 4x4?
Old Mar 16, 2022 | 12:08 PM
Boaterguy's Avatar
Boaterguy
I have not tried 4X4, will give that a shot and see what happens
254XP3
Dec 22, 2015 04:55 PM
MRMlandscapingDE
6.4L Power Stroke Diesel
Oct 23, 2015 09:15 AM
Landbarg
Apr 5, 2010 11:17 PM
bgreen1922
1997 - 2003 F150
Jan 12, 2010 07:19 AM
raptor131
Sep 29, 2007 12:17 AM
