Sponsored by: Real Truck
spark plugs
Old Mar 16, 2022 | 09:19 PM
xd2200's Avatar
xd2200
YES - OEM Motorcraft. Also, be careful where you buy them - much counterfeiting. I try to increase odds of getting the real ones by buying from a dealer
Old Apr 17, 2022 | 05:01 PM
klausd's Avatar
klausd
Would it be better to replace the entire coil plug or can I do just the boot and spring?
Old Apr 17, 2022 | 07:20 PM
WE3ZS's Avatar
WE3ZS
Its not a coil plug, you have plugs threaded into the heads, and coils on plugs (COPs) with rubber boots and contact spring in between. There is no reason to change COPs unless you have proven one or more to be bad. These coils tend to very long lives before failure. Unless you have a miss caused by a bad coil just replacing the plugs, boots and springs should make it run like new.
Old Apr 17, 2022 | 08:07 PM
klausd's Avatar
klausd
my obd sensor says I have multiple misses, i changed my plugs to OEM Motorcraft properly gapped and it still shows the code.
Old Apr 17, 2022 | 08:34 PM
WE3ZS's Avatar
WE3ZS
If your scanner isn’t showing which cylinder has a miss you can unplug each COP one at a time at idle and see which one doesn’t affect the idle to find a dead COP. A good COP getting unplugged will obviously negatively affect the idle.
6point0's Avatar
6point0
Does the truck run better?
did you clear the codes, and see if they come back?
Old Apr 17, 2022 | 08:59 PM
klausd's Avatar
klausd
Truck runs like dog ****, rough idle and no power and still showing multiple miss fires
Old Apr 17, 2022 | 10:24 PM
STOFFERJ's Avatar
STOFFERJ
1999 f250 super duty 6.8 v10 gas
so a 2 valve NPI v-10
Old Apr 17, 2022 | 10:26 PM
STOFFERJ's Avatar
STOFFERJ
is it true what they say about the plugs braking off when trying to replace them?
no, just no
A brand name I saw on rock auto
just stop, use the above mentioned Motorcrafts BUT I suggest you swap the coil packs and possibly injectors as there’s a lot more to this than you’re telling us
Old Apr 18, 2022 | 06:58 AM
WE3ZS's Avatar
WE3ZS
The truck and wiring harness is 23 years old, verify that the electrical plugs going to the COPs are still good and actually click onto the coils when plugged in. Sometimes the tab that allows for the click breaks and that doesn’t keep the plug fully seated which can cause a miss due to poor electrical connections.
Old Apr 18, 2022 | 10:14 AM
redford's Avatar
redford
FTE Leadership Emeritus
There are many things that will cause multiple misfires, even some that are not ignition related.
Can you tell us what specific error codes are being issued?
Old Apr 18, 2022 | 09:19 PM
klausd's Avatar
klausd
The only code that pops up is P0300
ROBBINthaHOOD
Jun 26, 2012 01:30 PM
400Nut
Modular V10 (6.8l)
Apr 3, 2011 12:23 AM
Brandon350
Modular V10 (6.8l)
Oct 24, 2008 10:29 PM
redwings
Feb 9, 2005 02:11 PM
Myckel
Modular V10 (6.8l)
Oct 10, 2004 09:55 PM
