Sponsored by: Real Truck
spark plugs
Old Mar 15, 2022 | 11:12 AM
klausd's Avatar
klausd
spark plugs
I have been reading different reviews for the v10 triton, what is everybody using?
Old Mar 15, 2022 | 12:11 PM
redford's Avatar
redford
FTE Leadership Emeritus
2V or 3V engines?
Old Mar 15, 2022 | 12:59 PM
klausd's Avatar
klausd
I'm not following the question
Old Mar 15, 2022 | 01:30 PM
Diamnd1's Avatar
Diamnd1
What engine do you have 2 valve or 3 valve? What year model is the vehicle so we can help you figure out which version you have. Spark plugs and procedures are different.
Old Mar 15, 2022 | 01:31 PM
klausd's Avatar
klausd
1999 f250 super duty 6.8 v10 gas
Old Mar 15, 2022 | 01:34 PM
Diamnd1's Avatar
Diamnd1
OEM Motorcraft plugs.
Old Mar 15, 2022 | 01:36 PM
klausd's Avatar
klausd
is it true what they say about the plugs braking off when trying to replace them?
Old Mar 15, 2022 | 01:37 PM
Diamnd1's Avatar
Diamnd1
That is the 3 valve engine. You have the 2 valve non PI(performance improved head) The 99 and early run 2000 V10 had very few plug threads and are highly prone to spitting them out. Especially if not torqued correctly.
Old Mar 15, 2022 | 03:45 PM
klausd's Avatar
klausd
The plugs that I need would have less threads?
Old Mar 15, 2022 | 05:57 PM
WE3ZS's Avatar
WE3ZS
No, the plugs that you need are the Motorcraft SP-479 and they have plenty of threads on them, it’s your cylinder heads that are short on threads. That’s why it’s so important to torque the new plugs to 25/27 ft/lbs to prevent them from working loose and blowing out, the factory spec was only 11/17 ft/lbs which seems to be a bit low with those few threads.
Whenever you replace spark plugs you should also replace the rubber boots and springs that connect then to the Coil On Plug (COP), for those the Denso (the OEM manufacturer) has the set of ten in their 671-0001 kit. If you need a new COP or two the Denso 673-6000 is the actual OEM unit for about half the Motorcraft cost.
Old Mar 15, 2022 | 06:15 PM
klausd's Avatar
klausd
Have you ever heard of WVE
Old Mar 15, 2022 | 08:32 PM
WE3ZS's Avatar
WE3ZS
No, what is WVE?
Old Mar 15, 2022 | 08:45 PM
klausd's Avatar
klausd
A brand name I saw on rock auto
Old Mar 15, 2022 | 09:18 PM
WE3ZS's Avatar
WE3ZS
Stick to the stuff I mentioned earlier, its all proven quality.
Old Mar 16, 2022 | 08:28 AM
Diamnd1's Avatar
Diamnd1
Do as stated above by WE3ZS. You will be asking for trouble if you try to go cheap with off brand parts.
It would be wise to have a Timesert on board should you have a blowout and an extra plug and boot.
++ Ford Spark plug Repair ++, ford spark plug blow outs, blow out spark plug ejection blow out, blown out sparkplugs, ford stripped spark plug, ford sparkplug blow outs, spark plug blow out ford, ford defects, ford spark plug repair ford, ford spark
