What Is This?
Old Mar 14, 2022 | 09:00 AM
ASFC27FTFBQ's Avatar
ASFC27FTFBQ
What Is This?
If this is nothing, I’d like to use it to drill a hole for future spot beams up front.
Thanks.
Old Mar 14, 2022 | 09:21 AM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
why not just use the upfitter wires, they are already there, i used several of mine.
Old Mar 14, 2022 | 09:48 AM
ASFC27FTFBQ
Good idea, but Rigid 360s come with a harness and I’d like to use it, if I can.
Thanks for the quick response.
Old Mar 14, 2022 | 10:03 AM
EXSwap's Avatar
EXSwap
I want to say this is the same hole/grommet I used to run a bunch of wire, clutch line, etc. through on mine when I did my swap. I just cut a slit through the middle and started shoving wires through. Grommet stayed in place.
Old Mar 14, 2022 | 11:15 AM
ASFC27FTFBQ
OOOHHH I like the sound of that; easy/peasy.
Thanks.
Old Mar 15, 2022 | 07:04 AM
Rubberduk's Avatar
Rubberduk
Not to hijack - but how does one find the upfitter wires? I'd like to wire up a few things like a dashcam and what not and this is new information to me...
Old Mar 15, 2022 | 07:43 AM
Dweber85rc's Avatar
Dweber85rc
Look under the hood and you'll see 4 wires that seem like they were cut off near the firewall on the driverside. Then look up under the dash.
Old Mar 15, 2022 | 11:07 AM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
Mine had 5, differing colors, coming out sort of by the brake booster, just dangling loose.
Old Mar 15, 2022 | 01:37 PM
turbodog's Avatar
turbodog
Ha! I always thought those where left over from some hack job. Like maybe an old alarm system. I bought mine two years old.
Old Mar 15, 2022 | 06:55 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
They are there so you don't have to bore a hole through the firewall, until you run out of them at least.
Can drive 5 things assuming you use the body/chassis for ground on both sides.
Sparky83
North Carolina Chapter
24
Sep 18, 2019 02:43 AM
Talyn
27
Apr 16, 2012 09:14 PM
hobbystock98
Paint & Bodywork
13
Jul 1, 2011 06:36 PM
ranger429
1978 - 1996 Big Bronco
Sep 29, 2008 02:15 PM
CBFryman
Sep 4, 2006 08:20 PM
