When I get a chance, I'll pull mine out and measure those hoses. I'm glad you posted this. I'm going to do the same before I install mine. Or have it installed...
Unless Jolly remembers and posts up...
Okay I measured the OD of the 3/8 inch ID fuel hoses with a micrometer, they all are 3/8 inch ID, the OD is approximately 16.25mm (loosely measured) which converts to 0.639 inches OD. I bet 5/8 inch (0.625") OD loom would work.
I'll post pics and have some additional info to post up.
Thanks! I'll get some ordered so I will have it when I install it all!
So I have some more questions... I was watching the Thoroughbred Diesel YT video for install. When reinstalling the upper intake he mentioned torquing to 89 in/lbs, then I think he said to get the temp up to 98* and retorque to 18 ft/lb. Then the 2 bolts on the lower intake are only 31 in/lb. So, did he just go back and retorque the upper intake bolts after letting it run a bit to get the temp up? Also, 31 in/lb on the lower intake... wow, that doesn't seem very tight. I guess this is because it's plastic though?
Fixes the problematic OEM heater inlet tube which is prone to corrosion and leaking at the thermostat crossover manifold.
Benefits:
Easy install— Simple instructions that even an amateur can follow.
Durable— made out of billet aluminum with the correctly sized o-ring rather than the factory thin-wall steel with a poorly fitted o-ring.
Cleans Up Engine Valley— Great for highly modified trucks looking to clean up the valley of the engine. Fitting converts over to a ¾” hose outlet.
Vehicle Compatibility:
2011-2022 Ford SuperDuty F-250/F-350/F-450/F-550 6.7L Powerstroke
The 6.7L Powerstroke has a thin-wall steel line running from the coolant/thermostat crossover manifold to the heater hose. It’s not uncommon to see coolant weeping there, specifically where the heater inlet tube meets the crossover manifold. This is due to both the metal properties, making it prone to corrosion, and the poorly fitted o-ring and tube design. Additionally, any time there’s EGR work, turbo work, or any other movement of the tube, leaking is more prevalent. This is mostly in part to the flawed design of the tube. With the SPE Heater Inlet Tube Fitting Kit we have resolved this issue.
Reason: add to post -- add link
I have been watching videos and then walking outside, popping the hood and then studying... Lol! I'm getting excited to do mine, but I know that once I get started I'll be a bit nervous. On another note, I'm hoping too that before I start digging into this I will see my DPF% start climbing again... being stuck at 0% for a couple of weeks now is making me nervous and if somethings going on I would rather wait to do this install until after figuring that out.
correct.
you do not want to introduce changes if there are open items.
if you have forscan or an idash, you can use that to see if your back pressure sensor is sending pressure data.
also, you can check you exhuast tip for black soot inside the tip end walls. If the end walls are black, that would be an indication of cracked ceramic dpf honey comb…which would explain back pressure loss if that is the case.
when mine had a cracked dpf and black pipes my dpf percentages and regens never changed, I drove it almost a year like that trying to find a dealer that would actually work on it and not just scan it and say it is fine.
Here is a PIDS list for the 2019 6.7 on the iDash. That seemed to be the most recent year on their website.
So, there are no codes popping up on the truck, or on the iDash or Forscan when reading them. I am hoping this is just me being paranoid, but the fact is, it has never taking anywhere near this long for my DPF% to start climbing. Right before my 700 mile trip home it literally went from 0%after I finished the regen to 5% overnight with about 10 miles of driving in between. So for now I am just hoping that due to a regen, then the very next day a 700 mile passive regen, and then a week later another full active regen... maybe my DPF is just super clean right now! LOL...
But otherwise, nothing. Pipes are clean as can be. EGT's are normal temps when driving. And according to the iDash, the DPF RG is something like 30% and the DPF SL is at 6%. One other thing I have thought about doing is to just disconnect the batteries for a few hours and then see if things reset.
I did see that I can monitor the Exhaust back pressure, however, I have no idea what it should be, so not sure what to do with that number.
By itself the back pressure doesn’t tell you anything terribly useful. To determine soot loading you’d also have to know exhaust flow and temperature then make what I suspect is a fairly simple calculation using flow coefficients unknown to us.
I finally worked my nerves up to ordering the DPK! I will install it during my next oil change, which will also be time for my first fuel filter change too, so I’ll knock it all out at once. I may have some more questions along the way… but for starters, is that just split loom you put on the hoses? If so, you remember what size?
The service manual says 18 ft-lb on the lower intake bolts. The upper intake bolts (with the exception of the frontmost one) are 89 in-lb + 98 degrees. The front upper intake bolt is 18 ft-lb. The 98 degrees is torque angle.
Edit: I don't have a torque angle gauge so I didn't do that, just the 89 in-lb. Should probably retorque them just to make sure.
