Should I install an O2 sensor?
Old Mar 13, 2022 | 12:28 PM
6t6merc's Avatar
6t6merc
I'm getting a new exhaust system. I'm thinking about having the shop weld in a bung for an O2 sensor. I have read that there are simple programs available that can read the O2 sensor output and show the air/fuel ratio. Any thoughts?
Eric
Old Mar 13, 2022 | 12:44 PM
Crop Duster's Avatar
Crop Duster
I have an Innovate AFR gauge and it works great. They will cause you to take your carb apart a lot looking for that perfect tune. They will help you clean up a too rich or too lean condition quicker than reading plugs. If you have dual exhaust, put a bung in both sides that way you can find out which bank is leanest and tune off of that.
Fair warning you will end up with a box full of extra jets, power valves, fuel restrictors, and air bleeds.
Old Mar 13, 2022 | 01:12 PM
6t6merc's Avatar
6t6merc
That looks like exactly what I need. Thanks for the good info Crop.
I am in the middle of a swap to propane. I don't completely understand propane tuning yet but I know there are far fewer variables than with a gasoline/carb system.
Eric
Old Mar 14, 2022 | 06:48 AM
Crop Duster
I've never had a propane vehicle, but there were a lot of farmers running propane back in the 70's and 80's when gas was expensive and hard to get sometimes. I know it burns clean and hot and usually requires hardened exhaust seats and good valves. In those days propane was nearly free about 20 cents a gallon, nowadays around here it is around $3.25 a gallon. Let us know how it works out.
Old Mar 14, 2022 | 08:18 AM
lizardman1's Avatar
lizardman1
Idiots in power, X2!!
Old Mar 14, 2022 | 10:53 AM
Red60's Avatar
Red60
Definitely have the bungs installed close to the engine/collectors. If you don’t use them initially, put plugs in them to cap being sure to use neverseize. This way your covered and it’s easier now than later welding the bungs on the bench.
Old Mar 14, 2022 | 03:27 PM
charliemccraney's Avatar
charliemccraney
Absolutely. It takes the guess work out of tuning and makes it so much easier.
Old Mar 14, 2022 | 04:19 PM
6t6merc's Avatar
6t6merc
Thanks for the replies. I see the guy tomorrow; I'll report.
Eric
Old Mar 14, 2022 | 04:29 PM
Thunderkiss1965's Avatar
Thunderkiss1965
Make sure to put the O2 bungs in the top half of the pipe to keep them dry or they wont last
radramrod2
Aug 15, 2015 08:30 AM
lupin398
Mar 19, 2011 09:03 PM
ctch88
1978 - 1996 Big Bronco
Aug 7, 2005 11:35 PM
nastruk95
General Automotive Discussion
Apr 27, 2004 07:32 PM
Dayne
1983 - 2012 Ranger & B-Series
Apr 8, 2004 11:27 PM
